Question about Compaq CV 7500 17" CRT Monitor
Compaq 7550 How do I adjust screen brightness?
  • 121 Answers
Try the buttons on the front or side of the monitor to get to the menu using the + or - to maneuver Thu the menu items until you see the "sun" that's for brightness the half filled circle is for contrast that helps too.
Posted on Jan 09, 2009
How to adjust screen brightness
follow the steps below;
At the right down part of your screen, right-click on your battery bar, scroll to "Adjust screen brightness"
Look down, at the middle of the screen, you will find screen brightness there.
I hope this helped.
Aug 21, 2014 | HP Compaq 6710b Notebook
I have a 7550 and the screen lights up but the menu does not come up - I have replaced the batteries. It was working when my sister gave it to me a couple of months ago.
Okay....I don't know if this will help, but this is one thing I learned about my Pfaff 7550. Sometimes it will look like the screen is lit up but there is no menu or anything and I have found that the "display lucidity control" dial is the problem. If you look just below the buttons that are in a semi-circular shape, you can see a really tiny little dial. It can be easily missed if you don't know where to look. What I have found is that sometimes the screen lights up but there are no words/menu and if you turn the "display lucidity control" dial, the words/menu will appear. As my machine has gotten older, it seems I need to do this more often. The first time it happened to me, I freaked because I thought the display (even though it was lit up) had blanked. THAT was when I discovered that teeny little dial that solved my problem. I don't know if this is your problem, but give it a try and see if works for you like it did for me. And by the way, if you need to see a diagram of the buttons on the Pfaff 7550, here is one. The "display lucidity control" dial is marked #23
Apr 05, 2014 | PfaFF Sewing Machines
I have compaq 7550 computer and my screen was to bright so i started trying to fix it well i messed it up real bad it douesnt fit my screen now plus it flickers now what do i do
RMB click on the desktop and select properties from the drop down menu.
LMB click on the "Settings" tab.
Select "True colour"
Move the slider to read 1024 X 768.
Change the refresh rate to 50Hz.
This should get you back on an even keel, you should then be able to fine tune the settings to what you prefer.
Jun 10, 2011 | HP Compaq FS 7550 17" CRT Monitor
The screen is tilted
You can adjust the keystone of the monitor..
this will remove the trapezoidal shape and square up the image to the monitor.
Check on the monitor for the menu controls and you should be able to find the keystone adjustments... allows you to adjust the upper width, lower width, etc...
Nov 27, 2009 | HP Compaq FS 7550 17" CRT Monitor
Vertical screen adjustment-compaq model 7550
u must click on any button on the screen and try to control one by one till u find the destination which u want
Jun 06, 2009 | HP Compaq FS 7550 17" CRT Monitor
Image on my monitor does not fill the how screan.
Use the control panel in front of the monitor to adjust screen.
Here's the manual for your monitor:
May 22, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
Depending if your video card settings and drivers are correct. First try to Right Click your mouse over the desktop area and choose properties. At the top tabs choose Settings, then on the lower left adjust screen resolution and click Ok.
Aug 24, 2008 | Compaq FS 7550 17" CRT Monitor
Screen on 7550 is upside down
there is a Windows XP setting to invert the picture (I guess it is if you hang the CRT upside down from the ceiling). I don't remember the key presses needed, but check under Properties for the CRT
Aug 19, 2008 | HP Compaq FS 7550 17" CRT Monitor
7550 brightens intremittently
some component might have loosen up on the circuit of your monitor! cleaning inside and resoldering loose components could fix your problem!
Dec 06, 2007 | HP Compaq FS 7550 17" CRT Monitor
Usercontrol automatically displayed when bootup
Please change the switch pannel  and check
Nov 19, 2007 | HP Compaq FS 7550 17" CRT Monitor
Compaq CV 7500 17" CRT Monitor Logo
93 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
