Question about Bissell Vacuums
I checked the belt and it has not broken, but when I start to vaccum the spinning head stops, and I start to smell a rubber smell...Do you think I need to replace the belt, I did get some string caught in it the last time I vaccummed, and it did stink like rubber then also...
  • 24 Answers
Yes you do need to replace the belt they stretch out. Think of a belt like a big rubber band if you were to stretch it out and hold a lighter to it the rubber band would stay stretched out. That is the same thing that happens when you get it caught on string or an area rug the brush stops but the little metal shaft keeps spinning creating heat and stretching the belt. Visit www.stevessewandvac.com for belts, bags or any other vacuum need.
Posted on Aug 13, 2008
Roller not spinning
Possible belt broken. If you smell an odor like burning rubber it could be the belt that turns the roller if not the belt could be broken already.Possible string or something else wrapped around roller. If you have animals in home they shed and the hair or fur gets wrapped around roller and it will stop the roller.
Mar 06, 2012 | Vacuums
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
My vacuum cleaner brush stopped rotating. Just before it stopped, I smelled some burnt smell. Any idea?
Almost certainly you have broken the drive belt. THese machines have a rubber belt that is designed to snap if you get the roller brush stuck on something. The most common reason for this to occur is that you **** up the end of a rug, the curtain or a sock. This will stop the roller but the drive shaft will continue to spin which chews through the rubber belt.
What you will need to do is buy a new belt and fit it on.
Hope this is helpful for you. If it is please take a moment to give me a rating. If you are in Australia and need somewhere to get you miele belt from try nelsonvacuums or VacuumSpot.
Dec 22, 2010 | Miele S184 Powerhouse Bagged Upright...
The spinning brushes on the vaccum no longer spin, how can i fix this? The vaccum picked up a very small wire from a video game and i turned it off immediately. I unwound the wire but the brushes no...
You have either broken the belt or more likely the clutch easiest is to replace cleaner head assembly £75ish or call Dyson and arrange a service if you're not DIY inclined but check belt !st
Oct 31, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I bought this second hand, so have no manual for parts, etc. I smelled something really bad, am assuming it was the belt. How do i release the head of the vaccume to get to the roller. It needs cleaned...
rotate the front belt lifter from green to red then rotate the locking knob above the nozzle. and the head will lift off. it helps if you put the height adjustment in the highest setting. did it smell like rubber burning?
Jan 01, 2010 | Kirby G5 Bagged Upright Vacuum
Vaccum cleaner belt change
If you've put a new belt on and you still are getting a rubber smell, then odds are that your agitator (the rotating brush) is not turning freely, and that means either (a) you need to remove the end caps and remove any hair / debris that is under those end caps, or (2) the bearing(s) of the agitator are bad. Depending on the model of the Sharp (which was not provided), you may be able to order just the defective bearings and replace them (or take the agitator to a vacuum shop to have them do it), or you can (or may need to) order the agitator assembly complete.
May 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Hoover Empower Widepath, brush won't spin.
The belt needs to be changed, it's probably spinning in place which is causing the smell (burnt rubber).
Dec 04, 2008 | Sandia Plastics Super Hipster Power Hepa...
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vaccum has no suction
Need a new belt -- you might have suction but you need the brush to spin (hard to help without make or model, upright or canister)
Oct 17, 2007 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
174 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
