Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Green Screen on Sony 40" LCD
I have owned this Sony 40" LCD for just over year and it is connected to an HD Satellite Receiver. Just recently when I turned in on the screen was completely green with the TV images in the background. After about 15 minutes the screen corrected itself and it appeared that it would be fine. However, when I turned on the TV the next day the screen was green again and it is has remained green. I have tried disconnecting the satellite receiver, power, etc. and nothing seems to work. It appears the issue is with the TV because the screen is green when all components are disconnected. I have 3 other Sony TV's in the house so I know everything is connected properly.
Does anybody have any idea why this is occuring and how I can correct ?
  • 2Putt Sep 02, 2008
    I contacted Sony Customer Service and they were great. Believe it or not they had a Tech at my house within a couple of hours to look at the TV. As it turns out, my Hi Def Satellite receiver had been sending a bad signal to the TV and the Tech was able to reset the receiver and TV to correct the problem. The TV is operating perfectly now.
    I was definately impressed with the quick response time and outstanding level of customer service provided by Sony.
  • 876 Answers
I just read this review :
I am extremely dissappointed with this Sony product and their customer service. After I had done tons of research and read hundreds of reviews on how good this t.v. was I finally felt comfortable spending this much money on a t.v. I was in love with this product at first. It was everything the reviews had said except it had slight clouding. Well, 1 year and 5 months after purchase the dang thing messed up.
I come home from work to watch some t.v....turn it on...and there was no picture. After a few seconds I heard sound from the speakers, so I automatically thought it was the satellite. A few seconds later the screen turned BRIGHT GREEN!!!! I unplugged the satellite reciever and tested it on the dvd player...same thing bright green screen. Unplugged everything and was just going to use the t.v.'s menu, but the same thing. I actually couldn't pull up the menu, so I knew something bad was probably wrong.
I called Sony customer service and went through a couple of trouble shooting tips, but they ended up ruling it unrepairable over the phone and said I had to take it to a service center. The service center tech called and said it was the CPU board and it would be $800-1,000 to fix. I called another service center and they said the same thing.
It was manufactured in Mexico, so if you are thinking about buying this model I suggest two things:
1. Don't buy it if it says "Manufactured in Mexico" with a manufactured date between August '06 - December '06
2. Get the extended warranty. Because lately I've seen reviews of the backlight going out or some minor problems that are happening shortly after the 1 year manufacturers warranty.
I am sorry to have to give you this info. I would call Sony service as He did and find out what they tell you. Here is the link for contact with Sony http://esupport.sony.com/US/perl/contact-land.pl
Posted on Aug 13, 2008
I own a 5 year old 40" sony bravia lcd tv, When
This sounds like what I managed to do to my screen, even though I knew better. Is there any chance you layed the screen face down at some time?
Even though you can still watch it OK, you probably have hairline fractures in the screen face (NOT the screen itself- be thankful for that- the cracks are in the screen coating). LCD screens are a very thin glass laminate with a thin protective glass-like coating. When they are laid flat (like I did to connect cables) if the screen bears any weight, microcracks develop on the front of the screen.
I am sorry to say that the effect is permanent.
Feb 24, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Screen is all Green
New cable box recently? If not, your cable provider has probably pushed a firmware update to your cable box. Green screens are very common with HDMI connection. From your symptom, I am going to take a guess that you are connected via HDMI. If so, switch to Component cables and your problem is solved. It's not the TVs fault... cable boxes seem to be the single largest problem child for HDMI compatibility. I hope this was of some assistance.
Apr 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
What is the best way to hook up my HD Mitsubuishi TV to a satellite receiver to get the best picture quality? I just recently got the HD receiver. Do I receive HD automatically through the receiver. I have...
The best picture would be with the composite connections which is the red, blue and green plugs. when using these plugs you will also have to connect seperate audio cables for the sound. Then select the proper input on the tv.
Nov 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My satellite HD DVR output is connected to the component video input (YPbPr) of a Sony KDF-E55A20 TV. I turned off the TV to change another input (video/l-r) to a different input but I left the HD receiver...
No, that will not damage the input. But if you are using component input and the green wire is off or not connected correctly it will prevent a picture from coming on. The green is the luminance and carries the main picture signal.
Sep 01, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV green screen after moving satellite receiver
a satellite receiver has its own coloring components inside it, if mixtures are not mixing properly. try that satellite receiver with differant tv. some with the tv,
Mar 27, 2009 | DISH Network 811 HD DTV Receiver
SONY HD TV 60"
It honestly depends on what type of TV. If it's a sony 60" it has to be a rear projection model, if it was bought recently or in the last few years it would be a LCD rear projection model. Repair is not impossible nor out of the question. If the green spot is a color stain burned on the screen it's replaceable. However, the cost of a new screen and with installation can be pretty high. Even if it's the LCD projector it's still repairable. Cost could be around 700-1000 dollars. If thats considered to expensive to repair then the answer is yes. Even if the TV did cost more than that you can find some awesome deals on new DLP TV's not to far off from that price range.
http://www.bestbuy.com/site/olspage.jsp?skuId=8824301&type=product&id=1212191771968
View this link for a good comparison.
Have a great day
Aug 11, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Installation question
For any electronic component, use the best connection that is available.
Good = standard composite/rca/yellow, red, white
Better = component cables (red, green, blue, white, red
Best = HDMI (find them cheap at www.monoprice.com)
Mar 25, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Dec 27, 2007 | Sony QUALIA 005 46 in. LCD Television
No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Sep 06, 2007 | Sony KDL-32S3000 32 in. LCD Television
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
579 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
