Question about Fuji FinePix S5500 Digital Camera
Fiji Finepix S5500
My camera opens up the lens deploys, it will connect to the computer etc, but when the power up is done and the lens deploys, the LCD screen shows the date and time setup, and asks to press OK for set, and back for NO. Trouble is the buttons do not respond to either when pressed. the camera appears to lock in that position. any ideas are welcome.
  • Anonymous Mar 31, 2014
    The lens comes out some times and will come out when I pull it then some times will not will not go back in please help
Solved my own problem, but for the benefit of others.
the camera is held together via about four/five small phillips screws. these need to be removed. the back of the camera will come away from the body. Make sure you don't pull too hard as there is a small connecting ribbon between the camera and the rear circuit board attached to the back. This ribbon is held in place at either end by small brown/tan coloured clips that hinge up to release the ribbon and down to clamp the ribbon to the connections. Try removing the ribbon ends and replacing it. If you are careful you can do this with batteries in place. Make sure you have your card in place, it won't work otherwise. I just realigned the ribbon and the camera works wonderfully. Might help with other errors. also a small ribbon attached to the multi function button, may have the same result for other problems. good Luck.
Posted on Aug 26, 2008
My camara is a finepix z i can se my photo on the camera but went i conected to my computer nothing happen my phto didnt come out event the computer dindt read the camera and nothing
You need to locate the driver for your camera, In a CD form or direct download form manufacturer website in order to have your laptop read the device you have to tell the laptop what device is attatched either by driver CD, or at fuji website for example.
look up your model on fiji site look for download drivers for your operating system on laptop XP vista etc.. then reboot your computer add the device by connector USB cord then it will see the device OK ? open My computer icon when it starts to see the digital camera icon
Jun 15, 2010 | Fuji FinePix Z10fd Digital Camera
Hi. I have a model S5500 that I have
I have one which you can buy off me... Everything is great with mine except hole where the tipod goes into has had the thread stripped and the flap for the battery door is broken... I also wanted to repair mine but can't find the parts. So I guess I could sell you mine as I have just upgraded to a Canon 40d.
Nov 05, 2009 | Fuji FinePix S5500 Digital Camera
How do I change the ISO/ASA and question on flash
Here's a link to a downloadable instruction manual for your camera: https://georgetownphoto.fotosource.com/downloads/camera_manuals/Fuji/DigitalCameras/FinePixS5100-S5500.pdf
Jul 03, 2009 | Fuji FinePix S5100 Digital Camera
Fuji finepix lenses
See my other post ref long/wide angle lenses.
Just check out ebay - look for fuji convertor lenses, a pair of basic Raynox long and wide angle lenses are about £100 although you can buy higher spec ones for significantly more. With Jessops going through hard times they tend to put these in their junk/clearance bins - I got my wide angle for £1.39 after waiting for about 3 weeks for it to drop in price. Check out when they are closing or clearing stock. Guess all high st retailers will be in the same boat wherever you are based at the moment so willing to sell-off slow moving stock.
Sep 27, 2008 | Fuji FinePix S5500 Digital Camera
Fiji s5500
If you have no data on the memory card, you should hook up the card to the computer. If your computer doesn't have a slot to insert your memory card, hook the camera up to the computer. Then format the memory card (if you don't know how to do that, reply and i'll type it out for you...)
May 12, 2008 | Fuji FinePix S5500 Digital Camera
Zoom error
You have to make sure you take the lens cap off first before turning on the camera.Cheers Sandra
Mar 02, 2008 | Fuji FinePix S5500 Digital Camera
Changing lenses
Tell me more about the lens- make etc full detail. Check also the Fiji web site for their lens's. Make sure you are attaching the lens the right way round- there is presumably a set of contacts that match the contacts on the body[A connectiviry issue] So far I am guessing but your remark 'See them all over the internet'leads me to wonder if some of this stuff is genuine Fuji or a reputable make.
Jun 02, 2007 | Fuji FinePix S5000 Digital Camera
Fuji S5500 camera and lens
It seems clear to me (and probobly to you as well) that the solution is to tighten up the lens. regarding the question if you can do it by yourself, i think the answer is probobly no. on one hand, there's a chance it is a very simple problem that only requires tighting a screw, however, i wouldnt risk a 500$ camera for a 30$ repair. my advice will be the local repair shop, if price is too heavy for you, and camera functions fine as it is, you can live with it for a while, just keep in mind it can get worse.
Mar 30, 2006 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji FinePix S5500 Digital Camera Logo
62 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
