Question about Olympus Stylus 710 Digital Camera
D:5f08 5e02 error
I tried all these solutions but none of them worked. i still have D:5f08 5e02 error coming up now d lens arent even coming out.
  • 1 more comment
  • makusmi4ever Aug 19, 2008
    Oh yes, my camera still have this "D:5f08 5e02 error". I've tried all these solution above. Anyone have another successful solution??? Thx very muach
  • adriano camp Sep 08, 2008
    Falha D: 5f08 5e02 olympus Stylus 700. como resolver?
  • Neusa Liquito Aug 26, 2013
    tenho o mesmo problema
If all mentioned solutions don't work I'm afraid there is one and only solution to this problem - replacing the lens.
I had the same probIem - 5f08 5e02 code on lcd - it is troubleshooting service code - malfunction of focus motor/sensor.
I've disassembled the camera, including the lens unit and found a damage in flexible connection between focus motor (including focus sensor) and the rest of the lens unit. There is a specific bending of this flex - it's located between the shutter/focus unit and the lens rings. As You power on camera, zoom in and out, and finally shut it off, all the time this flex is being bended in this specific region - one day it has to breake:)
It is almost impossible to buy it separely, even if You buy second hand camera with other malfunction there is no certainty how much this element will take.
Simply : buy another camera:) (I suggest Fuji - easly servicable)
Regards
Posted on Oct 02, 2008
Tengo el mismo problema
Posted on Oct 01, 2008
SOURCE:
How do i fix a Lens error in canon powershot elph 300hs?
None of the suggested solutions worked for me and my Elph 300HS. However, I took it apart, removing the back. There was a screw inside holding on the front panel which I could not budge no matter what, so I gave up. I put it back together, reinserted the battery, powered on and voila, it was back to normal. Perhaps disconnecting the battery for a while was key. Had I not tried the multi-step approach suggested, it would still be stuck.
Feb 23, 2012 | Cameras
GE j1455 Digital camera
Go to this website and try the solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Nov 02, 2011 | GE J1455 Digital Camera
Please help me in my kodak digicam, every time i turn it on , the digicam is automatically shutdown.... please help me
Make sure your battery is fully charged, clean the contacts on the batteries and inside the camera
If that doesn't work, try the suggestions on this site:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html.
If none of those suggestions work, it could be a jammed lens. Try these steps:
Even though the web page is titled "lens errors", it applies to stuck lens, also.
Good luck, hope this helps, and please rate this answer if it helped you.
Aug 30, 2010 | Kodak EasyShare M863 Digital Camera
CANON EOS REBEL XSI 450D BODY WHEN TAKING A PICTURE ERROR 99 COMES UP
Unfortunately, the Error 99 code is a catch-all code that means an UNKNOWN error has occurred. Because of this, it is difficult to pin down exactly what is causing the problem.
It could be a fault with either the camera (main circuit board, software, shutter mechanism etc.) or even the lens.
For starters, I would make sure that the lens electrical contacts are clean and the lens is mounted correctly and fully locked home. If you have a spare lens, try that also.
Next, I would reformat the memory card (do this in camera). If you have a spare memory card, try that also.
Check that the battery contacts are clean, and also the contacts of any external hardware such as vertical grips.
If none of these solve the problem, the only option left is to take it to a Canon service agent :-(
Hope this helps,
Matt
Apr 30, 2010 | Canon EOS Rebel XSi Digital Camera
What is error 99
What wide angle lens is it need f number it may be to old to work on eos 400d
Dec 27, 2009 | Canon EOS 400D Digital Camera
Sony Cybershot DSC-W150,screen reads turn power on and off again
You may not believe this and I hope you haven't spent a lot of money fixing your problem. I read that some people had a different error message coming up on their Sony Cybershot DSC-W150's and in order to fix it, they literally banged the lens against their knee while the lens was out and it re-focused and the error message disappeared. I tried this while my camera was doing exactly what you described above AND IT WORKED!!!!!!!!!!!!!!!!!!!!
After 2 or 3 firm blows, my LCD screen came up and focused. I can't believe it myself, but I was just desperate enough to try it and VOILA!
Good luck!!
Aug 11, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lens error 12 and 22!!!
The movement of the lens is motor driven. When you turn the camera on, the lens moves. The error 12, error 14, and error 22 refer to control stages in the lens movement ( I think error 22 means the lens won't retract). The lens housing and gear mechanism in this camera is plastic. If there is dust, sand, or debris around the lens housing, it may bind the lens when it trys to extend or retract. By banging it, you might work the gears loose or dislodge whatever is binding the lens (same with the "canned air" blowing out the dust). We've purchased a bunch of these cameras for our electricians in the field. Several have come back with this problem. I've taken the case off, and torn the lens assembly apart, only to find the plastic gears have been "buggered up". It's an inexpensive camera. Try to clean around the lens, give it a few slaps, push/pull the lens.... but failing this fix, buy a new one. Good Luck!
Jun 19, 2009 | Kodak EasyShare C330 Digital Camera
CD player error
Try and remove the radio fuse for 30 seconds to cycle power to the unit and then try to remove them. Some of these units have a software issue and a reset can clear it.
Aug 29, 2008 | 2005 Chevrolet Equinox
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Fujifilm A610
Try this solution: http://www.fixya.com/support/t143152-fuji_zoom_error_message
Jul 09, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Olympus Stylus 710 Digital Camera Logo
564 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
