Question about RCA Car Audio & Video
I was just wondering if you could tell me how to hook up the RCA 8" 120W Amplified Bass Injection System into my 1998 ford contour?
fastboyz
  • 674 Answers
SOURCE: wheel bearing ford contour
this comes a a hub assembly
you need to remove the brakes and brake rotor
the center nut holding in your CV shaft
in the hub you will find holes that you can put your socket threw to remove the mounting bolts.
Posted on Oct 18, 2008
SOURCE: 1998 ford contour fuse diagram
dont have an actual diagram but if you check at mastercraft.com they have a copy of the owners manual online and its free to access.
Posted on Dec 26, 2008
johnny5846
  • 379 Answers
SOURCE: need a diagram for serpentine belt 1998 Ford Contour 4cyl 2.0l.
98 ford contour 2.0 belt routing
here is a picture of routing and how to do it , etc. , good resource ..
J5
Posted on Jan 19, 2009
junmag
  • 175 Answers
SOURCE: 1998 Ford Contour ABS light and one wheel partially braking
could be but not likely. sound like abs pump or abs ecu failure. to make sure check DTC's
Posted on Jun 02, 2009
chispitas
  • 69 Answers
SOURCE: 1998 ford contour 2.0l Is this an interference
disconnect ignition power ... pull all your spark plugs and check for compression. quetions write back
Posted on Jun 09, 2009
How can I replace a valve body in my ford contour automatic transmission?
Have to remove the transaxle most likely ,
to get side cover off
That is not a home drive way job
Jan 18, 2013 | 1998 Ford Contour
Battery for a 1998 ford contour?
I bought an Everstart Battery from Walmart. They have a guide book to look up the battery you need. I have a 1998 Ford Contour SE 2.0Liter. It took a #43 Everstart Battery. It cost about $72.00. Hope this helps you.
Aug 25, 2012 | 1998 Ford Contour
I have a 1998 Ford Contour. I'm wondering the approximate cost to replace the muffler.
Just a muffler should cost you no more than $100 including labor.
May 11, 2011 | 1998 Ford Contour
I have a 2001 nitro bass boat an i am replaceing my 12v tolling motor w. a 24v. i installed the 2d battery and am ready to connect the wires. There are 2 positive wires, 1 states "battery a"...
Is this a straight 24V system... not a 12v - 24v.Correct..
The best advice is use a 50-60 amp resettable breaker..with 6 gauge wire (minimum 8 gauge) ... make sure your connections are clean, tight, and greased to prevent corrosion. USE a BIG HEAVY "jumper" cable between the + and - terminals.
Here are several sites that explain what you need to know..
I went from a 12-24v to a straight 36v Motorguide on my 21ft triton.. WOW!!!! talk about BAD A$$!!
I use the felt washers under all battery connections and the battery spray liberally on each connection..
24 and 36 volt Wiring Diagrams
24 volt trolling motor wiring Google Search
https://www.oreillyauto.com/shop/battery-accessories-16452/battery-accessories-16508/battery-cables---accessories-17650/2000/ford/contour?sort=price+asc
https://www.oreillyauto.com/detail/super-start-4986/chemicals---fluids-16461/battery-chemicals-17661/battery-protection/01342/4742198/2000/ford/contour
https://www.oreillyauto.com/detail/bwd-3123/battery-accessories-16452/battery-accessories-16508/battery-cables---accessories-17650/battery-cable/jc312/2601175/2000/ford/contour
Sep 18, 2017 | Nitro Boating
98 ford contour wiring diagram
When you tell us "wiring diagram", is for one specific circuit or you are refer to the firing order?
Apr 13, 2010 | 1998 Ford Contour
My speakers make almost no sound at max volume. However if you listen closely, the music still plays, its just not amplified. How can i check the amplifier?
if you are wanting bass adjust your amp settings to low pass. if you are wanting a lil bass- a lil treb- adjust your amp to full. and make sure your rca cables are hooked up in the proper spots.
Feb 08, 2010 | Car Audio & Video
Connecting an Altec Lansing ADA995 subwoofer system to a stereo
I have this exact Altec Lansing speaker system and I'm currently just using it with my Dell computer. But, I know you don't have to install these speakers to any high powered receiver for good sound quality. The subwoofer has two separate 200 watt RMS combined amplifiers built in for it's single knob controlled dual 6.5" bass drivers and 2-way magnetically shielded satellites, which are amplified together by any source that has an analog or digital volume control. The speakers act as a preamp receiver to any volume or frequency tone level controlled audio source. These input sources can also equalize the speakers receiving input signal for bass, treble or mid-range adjustments. You only need to obtain the proper adapter to hook up all the speakers to your desired component or device. Besides a computer, for example a TV with a variable audio out function or a mp3 player will work. The adapter that i am referring to is similar to what is included with certain 5.1 Logitech brand computer and multimedia speakers specifying gaming console and TV connecting. It has all three color coded 1/8" connector inputs on one end and RCA jack outputs on the other. This can be purchased more easily online then offline at stores such as Ebay for a fairly inexpensive price. However this adapter will not decode true 5.1 surround, but instead give a 5 channel stereo effect. I guess if one was looking for an inexpensive alternative solution to purchasing traditional high end home entertainment audio equipment, the ADA 995s are one of few computer speaker models in my book that can do a decent job.
Jun 19, 2009 | Altec Lansing ADA995 Speaker
I see 8 pages of downloads ford car and trucks **** no 1998 contour
check under/with European and British results for Ford Mondeo. you'll get more solutions, as Contour/Mystique rather failed in the states.
Jun 09, 2009 | 1998 Ford Contour
Car Audio & Video Logo
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeffrey Turcotte
Jeffrey Turcotte
 Mikey
Mikey
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
