Jan 8, 2009 - I hope its just a bolt on thing like B and D tranny. Any help would be great. .... The 2.3l four banger from the accord or cl will fit the v6 j30 engine. Is that rite? ... Do not buy a '97 to '99 3.0CL transmission and expect it to work in yourAccord. It will bolt up to the .... Honda 1998-1999 Accord - (3.0L V6) - B7XA
No they won't sorry, the wiring diagram is different and plug fittings differ. However, a compitent electrician can adapt the wiring to fit and make an aftermarket bracket to mount. Call around, Good luck
Suspension components on Accords are sealed and considered to be permanently lubricated. If they fail, they are replaced, so there are no fittings to lubricate.
The back brakes on my Honda Accord are disc brakes. After removing the brake cylinder assembly you will see the brake cylinder piston end has a slot in it. The short pin on the back side of the inner brake pad fits into this slot, but also it is used to 'Turn' (clock-wise) the piston back into the cylinder so you fit the assembly back over the new 'thicker' pads. You can not 'press' this piston back into the cylinder.
