Screen went blank while still on. unplugged power cord and when I plugged it back in the power on light went green. Problem remains
  • jasonmarden Aug 13, 2008
    This is a 27" tv purchased from Costco. I can turn off the power with the switch in back. But when I turn it back it on it will not respond to the remote or the front panel switch.
  • jasonmarden Aug 14, 2008
    Thank You Kevin
    I waited about 2 hours and the thing "fixed" itself.
    I believe it was just too hot. Once it cooled down it worked just fine. I will keep your solution for future reference.
    Genius:
  • 1,847 Answers
Resolution:
Follow the steps below to troubleshoot this issue.
Verify that the AC power cord is connected securely to a working wall outlet.
Unplug the power cord of the television from the AC outlet.
Let the television remain without power for 1 minute.
Plug the power cord back into the AC outlet.
Attempt to turn on the television.
NOTES:
If the issue is still unresolved after completing all of the troubleshooting steps, service will be required.
Make a note of the STANDBY or TIMER flash pattern when referring the television to service.
Posted on Aug 13, 2008
  • Legin Varghese
    Legin Varghese Aug 13, 2008
    Based on your description, the most likely diagnosis
    is a failure of the power supply stage although please understand that
    TVs are quite complex and diagnosing one without being in the same room
    is not easy.This area of the TV comprises some fuses, a bridge rectifier (4 diodes) a couple of capacitors, fusible resistors and a regulator. All are prone to failure.
    That
    stuff can be checked quite easily if you have a multimeter and a
    soldering iron. Is this something you think you are capable or willing
    to do?
    The first thing to check would be the main fuse.
    If you don't feel comfortable doing this, the repair cost will likely be between $200 and $400 depending on the problem.
My hp laserjet 1020 plus printer blinking both. when a click print, the orange and green light started bliking instead of printing and no printing
Hi.
I will suggest you try reset the printer, follow the instruction below to reset your printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
May 08, 2011 | HP LaserJet 1020 Printer
We were playing a game and the tv screen went black then we ejected the game and the wii console will not shut off and now it wont play a game or nothind then we tried to unhook it and the light stayed...
Power light is green or orange - TV screen is blank
    If the power light is green or orange and your screen remains blank, follow these steps.
    1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
    2. Make sure your Wii console has the most current Wii system menu. Download the latest update (how to), and then test your Wii console to determine if the problem has been resolved.
    If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired.
Jan 27, 2011 | Nintendo Wii Console
I unplugged my wii to move it to another tv and it after i plugged it back in the tv was black the volume worked and the controllers rumbled al the power was on and working,
Jan 26, 2011 | Video Game Consoles & Games
Sony Bravia - no picture, no sound. Just a blank screen. We were watching a show and the screen went blank and no sound.
First thing to try: unplug from the wall; count to ten; plug back in; try again
Second thing to try: unplug from the wall; count to 10,000 (or wait 10 minutes or so); plug back in; try again
#1 worked for me when it would power on with no video, no sound, just small green light + white logo
Dec 06, 2010 | Sony KDF-E42A10 42 in. LCD Television
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Hp cpus power supply green light constantly blinking
As always verify all cords are plugged in properly. After that it sounds like you power supply went out. It is not that hard to replace. Make sure you unplug power cord. After you remove the pc cover, Usually you just need to unscrew 4 screws for the power supply. Somewhere on the power supply it should say how much watts it is. Anywhere from 200 watts and up. Just replace with exact wattage.
Sep 16, 2009 | HP Media Center m7250n (ED842AA) PC...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Mitsu vs60603 menu ?
actualy the only wat to reset is to unplug the power cord for 1 minute the plug it back in.
Aug 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Electro Med Services...
