Question about Frigidaire ATF6000ES Front Load Washer
Front load wsher
When I push the bootom only thing run is drain pump but not draing and also no erro messg
  • 876 Answers
Go to www.frigidaire.com
>Customer Service
>Product manuals>your model number
>right click to download tech data, (which will give a repairmans info )and any other manuals you think you might need.
These are in PDF format. so if you don;t have adobe acrobat, you need to go to www.adobe.com/acrobat and download the free software so you can read the manuals. Once you have the manuals you can click on the little icon which is a stack of pages on the left column to go through the infomation,. Good Luck.
Posted on Aug 13, 2008
  • 725 Answers
Something is in you pump
Will not rinse and spin Very tempramental Have drained cleaned both filters
for any frontload washer to drain and spin two things must happen first doolock mechanism must lock and drain pump must start draining before anycycle can beging . what about checking for blockage between tub bootom hose to pump squeese hose with hand to feel any blockages to pump if no blockages replace pump. I beleive u need to replace your drainpump.
Jan 23, 2011 | LG WM-2277HW Front Load Washer
What does the erro code f-02 mean
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
Thank you !!
Jun 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
My washer stopped draing the water
The pump may have stopped running, or a hose is pinched or blocked. Check the hose port at the outer tub bottom to see if a stray sock or something is blocking water drain.
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch Front Load not draining
Sounds like a blockage. First port of call. Check where the drain hose goes into the sink trap of your Laundry Trough. Here in Australia we connect the drain hose into the sink trap. Most of the time if the hole drilled into the sink trap is not large enough it can create an obstruction in the waterflow out of the machine. Lint and stuff can build up and partially and at times fully block the exit into the trap. Try this first.
If that appears fine you should remove the drain in the front bottom of the machine. Use a bath towel to absorb the wter that exits as you unscrew the round plug in the bootom of the machine. If the plug wont unscrew or only partially unscrews you will need to call a technician to remove the drain pump and unblock things.
Goodluck. Let me know how it goes.
Regards Sam
May 25, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Code 5d comes on and it stops running
5d means the follow; possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
ERROR CODE F33 AND 5D
5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. F33 MUST be fix by a technition Service ONLY am sorry about this inconvenient. "Was this helpful?"
EFO, E10 error Message
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Frontload washer
you have a plugged drain pump.. remove the back .remove drain hoses remove drain pump and check for something in the pump... you may find coins or bra wires... hope it helps
Aug 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
