Question about Jenn-Air JSD2789GEW Side by Side Refrigerator
Freg side not getting cold
I tried everything, Defrosting, cleaning evrything but I don't hear any air coming from the freg side and I have everything open as we speaking and i am trying to guess which part is left to check and how.any idea of what is wrong or how can i test
  • 29 Answers
If you do not feel any air coming out there is probably something wrong with the circulating fan or fan blade broken,this can usually be checked by closing the doors or depressing the light buttons on both doors,you should hear the fan or feel flow,when you defrosted did you feel anything upon restarting?if so it could be a defrost problem
Posted on Aug 13, 2008
New refrig 1 year old and it runs constantly. what can I do to correct this problem
if the freg make more ice the problem is th thermostat but if the freg run without good cooling thats mean you micro-gas leakage
Feb 12, 2015 | Frigidaire 20.6 cu. ft. Top Freezer...
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator is not cooling on top part of freg side only the bottom part is cool. The frezzer is working fine.
You may have a circulation problem. Check the the vent, if it's a side by side, inside refrigerator, on top towards back and feel for airflow. If there is no airflow from freezer into the refrigerator then you may have a evaporator fan that went bad or else you have a defrost problem - evaporator is clogged with frost which inhibits air flow.
Nov 24, 2010 | Refrigerators
I need to store my freg, how long can I store it
You should be able to store it for many years. I would put a box of baking soda opened inside to absorb any smells. Also maybe put a couple mothballs behind the rear acess cover to prevent mice from getting in thier and chewing up the wiring or insulation. Here is a link for removing the rear cover if needed. http://appliancehelponline.com/referbackpanel.html
Jul 16, 2010 | GE Refrigerators
The freg stoped freezing avd getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | Frigidaire FRS23R4A Side by Side...
Why do i have water in my refridgerator
Air contains water particles and it will condense to form solid ic, you have to defrost your refridgerator on a regular basis and have to watch the water is drained up to the maximum extent
Dec 17, 2009 | Kenmore Refrigerators
Freezer freezes, freg doent get cold
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Freg stopped cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
o
Jul 06, 2009 | True GDM-10PT Refrigerator
No water nor ice comes out
do you have water pressure to ref. water control valve? check voltage to water control valve assy. note: very difficult to diagnose these control valves, replace them both and be done with it.
Apr 23, 2008 | Maytag MZD2766GES Side by Side...
Police sanner freg
Radio Shack should be able
to supply frequency manuals
Nov 14, 2007 | Office Equipment & Supplies
Jenn-Air JSD2789GEW Side by Side Refrigerator Logo
120 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
