Question about Teac GF-350 CD Shelf System
The record player skips
From the day we received the GF 350, the record player arm has not worked properly. It skips and will not move forward part way (usually about two thirds of the way) through the record.
We sent it to a repair shop and it sat there for almost 7 months without any repairs being done on it. We then sent it back to TEAC and they didn't fix the problem either. The manager acknowledged that only the CD player was fixed and nothing was repaired on the turntable even though the packing slip clearly indicated that it was the turntable that needed repairing. Unfortunately, we didn't check it within the "repair warranty" period and now we're stuck with this lemon.
If anyone has any ideas on how to fix the problem, we would really appreciate it. Thank you.
  • Anonymous Dec 28, 2008
    I have a different problem, the tone arm will not automatically return at the end of a record, but I wanted to point out that my GF-350 has no way to adjust the tracking weight - there is no wheel on the back of the tone arm. Those weights are found only on higher-end turntables, not a really basic one like this.
Hi There,
From your description it sounds like there is insufficient weight on the needle end of the pick up arm.
The pickup arm is very delicate in its balance at the "rear arm end" fulcrum.
This weight is adjustable to allow the needle to press on the music track to an exact pressure and it is adjustable so that this pressure does not damage the music track.
There should be a wheel type thingy at the rear end of the pickup arm.
This wheel is usually marked in Grams, and to make the needle end heavier to stop "skipping' you turn the wheel to wards the + sign.
This + sign means more weight on the needle.
There also should be a - sign, and the wheel, when turned in that direction, the weight on the needle is reduced.
You need to be aware that a needle really needs to exist in the cartridge as they can be broken off very easily and if there is no needle present there, then there is no way you will get any music from the turntable.
So check there really is a needle there...use a magnifying glass to see....
If thats OK then place the needle end of the pickup arm on to the record surface and turn the weight wheel until the needle just lifts from the record surtface.
Now that this stage has been received turn the weight wheel in the reverse direction by around 5-7 grams in the heavy + direction.
The needle should now be resting on the records surface and not lifting at all.
It should play like this,,,BUT please ensure the record player is on a perfectly flat surface the
needle wont work on any incline at all...
If you turn the amp on in the phono switch position and carefully hold the needle over the record and touch the needle with your finger you should get a scratchy sound from the speakers.....
This is a basic test to ensure the amplifier and all the wiring is in place and doing its job..
Im Sorry you had a run around from the repair company but some of them are not interested in repair work any more they just want to sell new hardware...
It pays to ask if they are Pepared to repair stuff for you , then get a commitment of a reasonable repair date and time in writing.
If this date and time is exceeded then you dont have to pay for the repairs do you??
As they have missed the service level agreement you had with them for the reapir date and time..
Hope this helps
Posted on Sep 27, 2008
Electro Brand model number 9801: I played one record, now when I tried to play another the turntable will not rotate. Could the motor have burned out that easily?
Listen carefully with your ear to the turntable when you move the tone arm towards the record. If you can hear the motor running and the turntable is still stationary then the drive belt from motor to turntable has probably fallen off of broken. Lift the turntable, there's normally a metal clip holding the turntable in place, and locate the drive belt.
Jan 19, 2014 | Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Teac GF-350 CD Shelf System
Recently purhcased new Gemini T 1000 turntable and it skips constantly when playing records. I allowed more weight to be assigned to the needle on the record and it helped slightly (up to about 1.5 from...
I'm no expert, but based on the general idea of operation for a turntable, it sounds like the arm is getting bound up or being hindered in some way. If you pick the arm up and swing it back and forth manually, can you feel a place in the movement that seems to have some degree of resistance? You would want to move the arm very slowly and feel for even the slightest amount of resistance. It doesn't take much force to hold the arm from advancing. An ill positioned wire in the base of the arm could be the culprit or if the unit has an automated return home mechanism, there could be a problem there as well. Maybe working the arm back and forth manually several times to its fullest allowable extension, will help to eliminate the impediment. Do this caringly and without excessive force. I hope this helps.
Jul 11, 2011 | Audio Players & Recorders
GF-350 will not record in the auxilary mode
Register and download the manual for free at
Page 20. What does it say about WHY it won
Mar 12, 2011 | Teac GF-350 CD Shelf System
Hello, this is Matthew Gonzales with DISH Networkhere. First thing I would check is the daily schedule, (press the DVR button3 times on your remote). You should be in a screen that has all showsthat are/were scheduled to record. If you select one of the events, itwill say why it did not record/why it was skipped. When the receiver isturned "off" it should be in standby mode, and your recordings shouldnot be skipped. The next step is to trydoing a hard reset on the receiver. To do a hard reset, you will unplug thereceiver from the power outlet, leave it for 15 seconds, then plug it back in.After doing this, your receiver will go through a rebooting process which takesabout 5 minutes. If the receiver is still not working properly, I willneed to dig a little bit deeper into the issue. Please feel free tocontact me at
Jan 02, 2011 | DISH Network ViP722 DTV Receiver /...
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
My brandnew Songwriter is not playing records properly. When a quarter is placed on the tone arm, it plays fine. Is there an adjustment I can make??? Marilyn
I didn't see the tone arm balance adjustment in the user manual, however that is what needs to be done. At the rear of item #39, on page 10, is there a dial with numbers from 0 to 4 or 5? If so, set the dial to "0" to see if the tone arm will "balance" (like a see saw) If not, the dial assembly (which is a weight) needs to be slid either forward or backwards to achieve balance. After balancing, turn the dial to a number higher than 0 to increase tracking force..keep increasing the tracking force until it stops skipping, but no more than necessairy. To much force causes wear/damage to albums. If there is no tracking force adjustment on the tone arm, I would suggest contacting Crosley @
Hope this helps.
Aug 18, 2009 | Crosley CR248 Turntable
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
Display problems
An analog video copy protection scheme that alters the unseen part of a video signal such that a VCR or other macrovision enabled device may not record the video signal properly. There are several types:
- Automatic Gain Control
- 2-line color stripe
- 4-line color stripe
Symptoms of this include picture fading in and out or color banding of the signal.
Feb 06, 2008 | Zenith DVC2200 DVD Player
Early tone arm pickup
On some record players there is an adjusting screw at the back of the tone arm that adjusts the tone arm drop in location but I don't think it will adjust the pick up point. That is controled by a steel rod under the record player deck that moves over and pushes a little trip lever near the center of the platter so that a gear is engauged and the end of record cycle is started. I'm not sure but you may be able to find an adjustment under the deck that is near the rotation point of the tone arm that will adjust that rod so that it will pickup later. Hope this helps some.
Dec 26, 2007 | Teac GF-350 CD Shelf System
Teac GF-350 CD Shelf System Logo
2,050 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
