1999 Chrysler Town & Country Logo
Posted on May 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brake lights on 1999 Chrysler town and country van does not work, any suggestions
ZJ Limited
Level 3:
  • Chrysler Master 17,989 Answers
  • Posted on May 11, 2011
ZJ Limited
Chrysler Master
Level 3:
Answers
17989
Questions
0
Helped
14457990
Points
60858
Check fuses, wires and bulbs, finally check brake switch, generally is located backside brake peddal.
2004 Chrysler Town and Country won't start. Lights, radio and horn works just fine. Even put in a new starter and still get nothing. Ran a wire from battery to the starter and got a little kick.
Chrysler Town & Country Questions - My van won't start ...
www.cargurus.com > Questions > Chrysler > Town & Country
CarGurusSep 29, 2008 - ckf2004 answered 4 years ago. I have a 96 chrysler town and countrylx and the engine died, turned over but wouldn't start, I researched and replace the flywheel .... My van sometimes won't start because it kills the battery.
My town & country 2004 wont start sometimes - CarGurus
CarGurusMy town & country 2004 wont start sometimes - My van start doing something really weird. it will ... Asked by TownCountryguy May 03, 2013 at 03:31 PM about the 2004 Chrysler Town & Country Base .... Sometimes you tap it & it won't work.
Van won't start - Chrysler town and country - YouTube
? 1:01
https://www.youtube.com/watch?v=mkEL2vlLZr0
Jun 26, 2014 - Uploaded by Philip Walker
We have the same issue currently...very randomly...with our 2008 Caravan at the moment. Wife just got ...
2011 Chrysler Town & Country Engine Won't Turn Over, Will ...
www.carcomplaints.com/Chrysler/Town_Country/.../engine_wont_turn_...
The 2011 Chrysler Town & Country has 34 complaints for engine won't turn over, will not start. Average repair cost is $902.00 at 58178 miles.
My wipers...lights..radio and horn went out but I can drive the car..what would cause this?
2008 Chrysler Town & Country Intermittent Electrical Failure ...
www.carcomplaints.com/Chrysler/Town_Country/.../intermittent_electric...
The 2008 Chrysler Town & Country has 25 complaints for intermittent ... The horn,lights, wind shield wipers front and back going crazy could not shut off. .... I was Driving down the road and my van went crazy possessed! ... Electrical checks reveal nothing wrong with the electrical system, and there is power to the radio.
2003 Dodge Caravan ES Electrical Problem - Discussion on Topix
www.topix.com > Dodge Grand Caravan
Aug 7, 2011 - my van was running fine, shut it off, went in for half an hour then it would not ... or the electric doors. windows do and brake lights. heater stays on hot and i can only ... My horn wipers,power windows, radio,blower front and back, headlights, do not work. ... Chrysler Readies Next-Generation Town & Country.Missing: 2004
Thread: I lost almost all of my dash lights, instruments, and ...
forum.chryslerminivan.net/.../7261-I-lost-almost-all-of-my-dash-lights-i...
Jan 17, 2008 - 10 posts - ‎6 authors
I have a 2003 Town and Country mini-van and I lost power to all my ... In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well. The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work.
Will the alarm system stop my 1999 town and country van from starting
Probably needs the fuel safety shutoff switch resset. I am not sure where it is on a Town and Country van.
1helpful
1999 chrysler town /country van .horn blowing lights blinking wont stay running or wont start
This is your security system. Your van thought it was being stolen. Next time do not leave your keys in the van and lock the doors.
1999 town and country van, battery indicator light came on, stayed on, then power was lost to the van slowly- first the radio, then then abs light went on then the windows didn't work finally full display...
double check the battery terminal or wire connector if loose,go to nearest autozone to check the load test on the alternator,your alternator might loosing it already.
I have a 2008 chrysler town and country van. It has a warning light with a ! in the middle. In the upper left corner. What does that mean? Thanks, Brandi
that sholud be a brake light due to a parking brake engaged or not fully released it can also com on if there is a abs malfuntion or brake fluid is low. You need to get your brakes checked. If fluid is not low brakes are good and parking brake is not on you may need a brake switch.
1helpful
How to remove, and install a brake light switch in a 2003 chrysler town & country van
you need to lay on your back and follow the brake pedal up so far and you will see the brake switch attached to it,you will need to pull out a large hair pin clip,and wiggle the master cylinder rod and the switch off together,
1helpful
Van brakes squeal/whistle even when stopped
Sounds to me like a dry, loose or worn serpentine belt. With the motor idling, lightly spray the serpentine belt as it's spinning with WD-40 or other oil based lubricant (Don't spray near the alternator). If this doesn't work, turn the mortor off and check the tension and for cracks or worn spots. The brakes will not squeal when you are completely still.
2helpful
All the accessories are dead on my 1996 town & country .
this problem is caused by a defective BCM (body control module)
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
