Question about Canon PIXMA iP1600 Printer
Printer error message
Printer does not recognize one or both of the cartridges. Both cartridges have been replaced, but still getting the error message.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Did you try a clean and alignment yet?
Posted on Aug 19, 2008
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
Printer Does not recognize Color Cartridge Error 3603 for ESP 3250
Are you using "compatible" cartridges? That is usually the problem. Try using Kodak cartridges. If that doesn't work, it's the printhead. You could try cleaning it.
Nov 03, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
Printer doesn't recognize replacement ink cartridges
Most of the printers have the heads right on the cartridge and if you will notice there is some circuitry on the side which also has electrical contacts that connect the print head to the printer. There are many contact points that must be made between the cartridge and the printer. If the connection isn't perfect, you will get the error message Cartridge Not Recognized.
Dec 06, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Brought c5180 two 1/2 years ago. starting using product 8 months ago, printed maybe 500 pages. replace ink when needed. now printer say i need to replace cyan ink which i did twice. brought it in for...
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
  1. Lift the top cover. Figure 1: Lifting the top cover c00372271.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge c00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge c00372273.gif
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts c00372274.gif 1 - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Or Please let me know what is the exact error message you are getting.
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
My hp3030 does not recognize the printer cartridge.
Those cartridges have a little chip that tells the printer that it's there. Check the contacts on the cartridge. If the old one is still recognized and the new one is not, then return the new one and get it exchanged.
Jan 21, 2009 | HP LaserJet 3030 All-In-One Printer
MP500 ink tank cannot be recognized error U043
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
41 people viewed this question
old marine
old marine
