Question about Kodak EasyShare V1003 Digital Camera
Transfering pictures from camera to computer
I cannot work out how to transfer the picures on to my computer, i have connected the usb cable and nothing is comin up on the screen and i have installed the disc
    Problem Solver:
  • 37 Answers
Do you have microsoft picture manager? You may need it. If it's an apple, They'll come up on preview, then you'll have to load them onto the desktop.
Posted on Aug 19, 2008
How to transfer images from computer to nikon coolpix
I don't understand why you would want to transfer pictures from the computer to the camera. Normally you transfer pictures from the camera to the computer. But, if you really want to restore pictures to your camera's memory, you can remove the SD memory card from your camera and transfer the pictures on any computer equipped with an SD card reader/writer. These devices are built into most Apple computers, many PC's and are available as USB accessories for all other computers. I have seen them for under $20. When you connect the device and insert your camera's SC card, your computer will recognize the card and treat it as if it were another hard drive. You will be able to read or write or drag and drop picture files just as you would with any other file on your computer. By the way; most professional photographers use this method to transfer there photos rather then transferring them using a USB cable from the camera.
Jun 27, 2014 | Nikon Coolpix 4100 Digital Camera
How to import picture from Samsung camera PL120?
Transferring files by connecting the camera
as a removable disk
Connect the camera to your computer as a removable disk.
1 In Shooting or Playback mode, press [m].
2 Select Settings - PC Software - Off.
3 Turn off the camera.
4 Connect the camera to your computer with the USB
cable.
Transferring files with Intelli-studio
Intelli-studio will start automatically when you connect the camera
to your computer with the USB cable.
The battery will charge while the camera is connected to a computer with the
USB cable.
2 Select Settings - PC Software - On.
cable.
5 Turn on the camera.
• The computer recognizes the camera automatically and
Intelli-studio launches automatically.
6 Select a destination folder on your computer, and then
select Yes.
• New files stored on the camera will automatically transfer to
the selected folder.
• If your camera has no new files, the pop-up window for saving
new files will not appear.
Rate my answer if this helped you.
Sep 13, 2011 | Cameras
I have had a Nikon CoolPix L110 for 10 months. I've never encountered a problem transferring pictures from my camera to my computer during this time...until now. When I connect my camera using the USB...
Welcome to Fixya
Try the alternate way of transferring the pictures to your computer instead of using cable.
To download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer. Once the card is plugged in, it will appear to your computer as a removable drive. Just drag&drop pictures from the card to the computer's hard drive, the same way you copy any other files.
Thanks
Apr 23, 2011 | Nikon Coolpix L110 Digital Camera
Trying to transfer pictures taken on nikon coolpix L4 to apple imac computer. i have the cable plugged in to computer. camera says preparing to transfer but doesn't transfer. what can i do? i have...
Welcome to Fixya
Thanks
Mar 06, 2011 | Nikon COOLPIX L4 Digital Camera
When I plug cable from camera to USB computer connection, nothing happens!
Not enough information. The transferring of files requires a sequence of functions to happen before the pictures will transfer to the computer. You will need the camera software installed on the computer. The camera sequence for transfer and each camera is different, some just need you to turn the camera on after connecting the USB cable while others require you press the "Playback" button to transfer files. Depending on the camera software installed on a computer they "normally" download to a file folder then the pictures can be opened in the software programing.
Feb 08, 2011 | Cameras
DSC-S730 copy my picture to my computer?
The procedure to transfer pictures to a Computer depends on whether or not the Camera has the capability of using Picture Transfer Protocol (PTP). If the Camera is capable of PTP (in this case; DSC-S730 - YES), set the USB mode in the Camera menu to PTP and then use the PTP procedure to copy the pictures to the computer. Otherwise, use one of the standard USB transfer procedures.
This procedure must be performed while logged in as Administrator or to an account with Administrator rights:
  1. Turn on the Computer.
  2. Turn on the Camera.
  3. Insert the recording media containing the pictures into the Camera.
  4. Set the USB connection or Transfer mode setting in the Camera menu to PTP .
  5. Use the USB cable supplied with the Camera to connect the Camera to the Computer. NOTE: Connection through a USB hub or other USB device --such as a printer or keyboard-- is not supported and cannot be guaranteed. The Camera should be connected directly to a USB port on the Computer.
    NOTE: The Scanner and Camera Wizard should automatically start.
  6. In the Scanner and Camera Wizard window, click the Next button.
  7. Under Choose Pictures to Copy , do one of the following:
    • Click to select each picture you want to copy.
    • Click Select All to select all the pictures for copying.
    NOTE: Selected images will be marked with a green check mark.
  8. Click the Next button.
  9. Under Picture Name and Destination , in the Type a name for this group of pictures field, enter a name for the folder where the pictures will be saved.
  10. Next to the Choose a place to save this group of pictures field, click the Browse button.
  11. In the Browse for Folder window, click to select the location on the computer where you want to save the pictures.
  12. Click the OK button.
  13. In the Scanner and Camera Wizard window, click the Next button. NOTE: The pictures are copied to the Computer.
  14. After the transfer process it finished, under Other Options , click to select Nothing, I'm finished working with these pictures .
  15. Click the Next button.
  16. Click the Finish button.
If you are still unable to transfer pictures, please switch the USB mode of the Camera to Normal or Mass Storage and try again.
After following the steps above, the pictures from the camera should successfully be copied to the computer. If for some reason the pictures did not copy, try using the method for standard USB picture transfer.
I'm assuming you are using the Windows XP Operating System in the Computer. If not then follow this link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C116935
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Connecting the Canon Powershot A540 to a computer
First you should have a program installed in your computer to transfer your pictures, best is canon's.
Once the USB cable is connected you should turn your camera on, automatictly the program detects your camera and asks you to press the transfering button. Good Luck.
Sep 21, 2008 | Canon PowerShot A540 Digital Camera
No pictures
Have you checked the HP hep site?
Here is their suggestion
Introduction This document explains how to transfer images from the camera to a computer running Windows XP operating system by using a universal serial bus (USB) cable. Transferring the images Follow the steps below to transfer images from the camera to a Windows XP computer. Step one: Connect the camera to the computer
  1. Turn off the camera.
  2. The camera came with a special USB cable for connecting the camera to a computer. Connect the large end of that USB cable to the computer. Figure 1: Connect the USB cable c00878070.gif
  3. Open the rubber door on the side of the camera and connect the small end of the USB cable to the USB connector on the camera.
Step two: Transfer the images Choose one of the following methods to transfer the image files: Method one: Transfer images with the HP Photosmart software
  1. Make sure the HP Photosmart software is installed on the computer. If the software is loaded, then go to step 2. If the software is not loaded, click here to upgrade to the latest version of imaging and printing software (in English).
  2. If images on the camera are selected for printing or selected for HP Instant Share destinations, make sure the computer is connected to a printer and the Internet.
  3. Turn on the camera. The HP Import Photos software starts on your computer. If you have set the software to automatically transfer the images in the camera, the images automatically transfer to the computer. Otherwise, in the Transfer images from Camera/Card screen, click Start Transfer . The images are transferred to the computer, and then if there are any still images that were previously selected for HP Instant Share destinations, those actions are started.
  4. When the Image Action Summary screen appears on the computer, you can disconnect the camera from the computer.
Method two: Transfer images without the HP Photosmart software If you do not, or cannot, install HP Photosmart Software on your computer, you can still transfer images from the camera to the computer using the Picture Transfer Protocol (PTP) in Windows XP. Follow the steps below to transfer images.
  1. Turn on the camera. Windows will automatically launch a program to transfer the images.
  2. When the images have finished transferring, disconnect the camera from the computer.
  3. If you encounter problems, check that the camera USB Configuration in the Setup Menu is set to Digital Camera .
    1. While in Live View , press the Live View/Playbackc00591915.gif button, and then press the Menu/OKc00280209.gif button.
    2. Scroll to the Setup Menuc00595863.gif using the left/right arrow c00280208.gif buttons.
    3. Use the up/down arrow c00280207.gif buttons to scroll through the Setup Menu to highlight the USB option.
    4. Use the left/right arrow c00280208.gif buttons to change the setting to Digital Camera and then press the Menu/OKc00280209.gif button.
    5. To exit from the Setup Menu , press the Live View/Playbackc00591915.gif button.
  4. Reconnect the camera to the computer.
Mar 06, 2008 | HP Photosmart M415 Digital Camera
Pictures not transferred to the computer
The cause and solution may include one of the following: The AC adapter or USB cable is not securely connected. Check the connections, and then try transferring pictures again. Kodak EasyShare software is not installed. Install the software. There are too many programs running on the computer. Close all software programs and try transferring pictures again. The camera was removed from the dock during picture transfer. Replace the camera on the dock, and press the Transfer button. The Transfer button was not pressed. Press the Transfer button.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
43 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
