Question about Amana PTH153B35AE Air Conditioner
Blower will not work
Amana 80 sse blower will not work. I hear a click when I switch blower to on as well as heat but blower does not work. I see one red flash. Additionally, the filter was VERY dirty. Any suggestions?
2 Suggested Answers
  • 230 Answers
SOURCE: Need to know what size
The blower size is selected based on the details of your home. The size of the motor must match the tonnage of the A/C. The tonnage of the A/C will be determined with a heat gain/loss calculation.I believe there are at least 2 options for this furnace 3 Ton, and 4Ton.
Posted on Jul 03, 2008
tborn6
  • 700 Answers
SOURCE: furnace manual
here's the link for your problem and I hope that it helpshttp://johnstonesupply9.com/TechDocs/Amana/Gas%20Furnaces/GCIC%20Gas%20Furnace/GUIC%20GCIC%20TECH%20INFO.pdf Thanks for unis FixYa!
Posted on Dec 23, 2008
How do i reset power to thermostat from amana furnace is there a reset for controls?
The manual says it should automatically reset. However to manual reset the unit it says to "interrupt" the power supply. --which I think means unplug/turn off electric to unit for 20 seconds. If you do not have the manual go the manuf website and download it. --Also, this is a Goodman unit. If it does not reset something else it wrong that is preventing the unit from starting for safety reasons.
Sep 01, 2014 | Amana GMH81405DN 140,000 BTU 80% Gas...
Amana 80 sse flame rollout sensed what does this mean and how do I fix.
The flame rollout switch is located in the burner box on the left side on an upflow model. There are two wires connected to it .between the two connections is a small red button. Depress this until you here a small click. This should reset the switch. These
switches usually open because the flame is "rolling" back instead of being drawn into the furnace.start furnace and check for flame rollout.when the main blower fan comes on if you notice any change in the flame turn furnace off and call a qualified service person as this could indicate a cracked heat exchanger and could cause carbon monoxide to enter the house a potentially dangerous situation. I strongly urge anyone with a gas appliance installed to have a good carbon monoxide(CO) detector installed also. Hope this helps.
Dec 10, 2013 | Heating & Cooling
Amana 80 sse
Amana aircondition window unit wouldnt turn on. E2 indicator light was on. I turned off breakers and turned them back on as suggested for an Amana furnace. Yay, it works now. Thank you.
Jan 19, 2012 | Amana Heating & Cooling
No AC air flow Amana 80 SSE
hi! the problem is the fan motor or supply not sufficient.
Sep 08, 2009 | Heating & Cooling
My amana 80 sse furnace will not heat. looks like furnace light is off. what can i do to reset it. thanks
Turn off breaker. Turn it back on. If furnace is completely dead still, change your transformer. It's cheap..
Dec 11, 2008 | Heating & Cooling
Amana Gas furnace, Air Command 80 SV. Does not ignite. The blower turns on, then gas valve opens. I can hear a mechanical switch close, which is probably the igniter control. But no spark, no flame. ...
Buy a new ignitor here; The Ignitor Store. Or talk an Amana dealer/Contractor to sell you one. They can range from 15 to 35 bucks! Depending on their mark-up. Give them your model number, and or ignitor part number. Their simple to change out, good luck, please contact if you have any questions.
Dec 02, 2008 | Amana Heating & Cooling
A/C turns on and cools but Heating system does not turn on when switched fron a/c to heat. All I hear is a click form the heating system.
Depending on whether you have a gas or elec. heating system it could be a fan control module or a heat sequencer. It's not the thermostat since it is clicking calling for heat. It's not the blower motor because it comes on during cooling. Either way it's an inexpensive repair.
Oct 13, 2008 | Amana Heating & Cooling
Need to know what size Blower motor I need for and Amana SSE 80 furnace.
Jul 02, 2008 | Amana Heating & Cooling
Furnace manual
May 26, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH153B35AE Air Conditioner Logo
46 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
