Question about HP LaserJet 3310mfp All-In-One Printer
3310 all in one printer
All the colors work except the black ink . switched to new cartridge but it still does not work.
  • W8ting4him Sep 12, 2008
    same problem with printer printing gray even after new cartridge
pishta68
  • 579 Answers
SOURCE: ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Posted on Jul 07, 2008
worldvet
  • 859 Answers
SOURCE: hp 3310 photosmart only prints in yellow
On the left side of the print head carriage is a white plastic gear that drives the ink pump. Check it first to see if its firmly in place, has chipped or worn off teeth or looks damaged in some other way.
If this white gear driving the ink pump is damaged or looks odd let me know right away so we can address this issue.
Now, there is a trick for resetting your particular HP printer. This sounds and is convoluted but it will work. However, the system will think all your ink cartridges are full. If they are rather full okay. If they are near empty you will want to run this hack again as the ink nears low. You won't get a ink low warning correctly after this until you've installed new full tanks eventually.
Turn the printer on. At the same time, using your left hand, press the OK, Cancel, Black, and Color buttons down and hold them down. While holding these down buttons use your other hand to turn the printer off, still holding the four buttons down with the left hand. Once the printer has powered down fully you can release the buttons. Now, the printer will initialize and then run a maintenance check. If you printer is otherwise okay, no damaged circuitry or gearing you will be fine. Turn the printer on. It will start up and shut itself off, this is expected. Once it is off again, turn it back on once more and this time the printer will run the maintenance routine. Have paper in the feed tray.
1.) Check left side of printer carriage for the white gear that drives the ink pump. Look to see if the gear is off, broken has worn or chipped teeth.
2.) Turn the Printer On.
3.) Hold down the OK, Cancel, Black, and Color buttons with your left hand and hold them down.
4.) Use your other hand to turn the printer off. Keep your left hand on the buttons until the printer is off.
5.) Turn the printer on, wait for it to turn itself off. Have paper in the feed tray.
6.) Turn it on again and it will enter the maintenance mode. Follow any prompts during the maintenance mode, if any.
You should be back in business now. If not, try the routine again, sometimes you have to run it more than once. Should it still fail, let me know as you may get an error message and error number.
Use the Comment Text Entry Box below to comment back with any other questions or point out failures in this hack.
Regards,
Worldvet
Posted on Nov 20, 2008
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
  • 672 Answers
SOURCE: just installed refilled color and black ink
I found these instruction at out-of-warranty.com They seem like a possible solution.
Steps:
  1. Press Cancel and Power, at the same time.
  2. Then, the Unit will ask for a Key Combo, press blue, green, gray buttons (in order) for this.
  3. “Support Menu” should appear.
  4. Go to Resets menu and use the semi-full reset.
I hope this is helpful. Good luck.
Posted on Sep 05, 2009
  • 12 Answers
SOURCE: Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
Posted on Mar 14, 2010
HP 3200 Photsmart Printer will not print properly.
You can always perform the print nozzle cleaning procedure through your printer's software. If it is new, then the black cartridge has malfunctioned. Take it and your receipt to exchange it for another. I'll bet this is the problem since your color is working OK and your text is grayscale (partially working).
Jul 19, 2009 | HP PhotoSmart 1215 InkJet Printer
Will not print Magenta
it seems that your cartridge nozzle is dryed out u can try to clean via the hp tool software or via the menu on your printer if that not works try a new one and if that is not working than call hp for support
Dec 17, 2008 | HP Photosmart 3310 Printer
My ink ran out and I replaced both the black and color inks. The black is ok, but the color still show that it needs ink. Now my printer won't work. Can you help me?
Yes, I got it solved. I returned the first ink cartridge and got a new one, Ir works fine now, except the red is more pink than red.
Nov 04, 2008 | Office Equipment & Supplies
Black ink leaking from bottom of printer!
There is a ink resovier where the cartridges are cleaned of excess ink after a job. That gets filled over time and gives you the leakage described. Very messes job to clean it.
Sep 10, 2017 | HP Photosmart 3310 Printer
"Expired color cartridge" message blocks black printing - nothing works
Hello merelU. I'm afraid you may have to replace the empty color cartridge as there may be problems with the printer while an expired cartridge is installed on the printer (even though some of the cartridges are still under warranty) and also, HP cannot guarantee the quality or reliability of expired ink cartridges.
all the best.
thx
Oct 07, 2008 | HP Photosmart 3310 Printer
HP 3310 - problem with black ink supply
I heard you can get the 3310 to do a pump up the tubes cycle but i don't know how to make it do it. Pressing the ok and cancel buttons when you power up didn't work for my machine. Which has too died a inkless black death!
Jan 31, 2008 | HP Photosmart 3310 Printer
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP 3310 ink cartridge not recognised
My HP 3310 wil not print black. The color prints fine. Spent 2 hours on the phone with HP support only to be told to buy a new printer. The machine is less than 2 years old. There must be a way to repair this. Any ideas? Barbara
Nov 08, 2007 | HP Photosmart 3310 Printer
HP LaserJet 3310mfp All-In-One Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
