Question about Toshiba 32A33 32" TV
My Toshiba with a little crazy man inside - Help!
Tv is just over 3 yrs old. When turned on it goes straight to the "MENU" screen. On some occaisions when tv is turned on it may show picture for a while then goes to the "MENU" screen. Runs thru menu and changes items like language... to spanish or french. Also switches to VCR mode or TV 1 AND TV 2 is shown on the screen. Most times channels will not change by remote or tv. I have replaced my remote with a new one and still does not work. Is this a 3 year throw away model? or is there someone at TOSHIBA that cares? Is this help line for real help or just bloggers? Very frustrated
  • Gsava Aug 13, 2008
    Are you saying I need to replace a part called the 'tuner card? Please clarify /confirm.. Is this an internal electronic compnent ?
    What is a tuner card and how do I replace it?
    Brigadier General:
  • 6,966 Answers
I beg to differ. The tuner is responsible for selecting TV channels and not the Menu display. Menu display as well as all other functions, channel selection, volume up down are a function of the logic controller. Think of it as a small computer that is responsible for the overall control of the TV.
Initially, what would probably be faulty is the software/firmware that manages the logic/controller board. The only easy user action is to reset the unit. This is simply unplugging from the mains in the hope of reverting the unit back to factory default. Pls unplug the TV from the mains for a couple of hours. Additionally, pls remove the batteries from any or both remotes. This is to ensure that it is nether remote inadvertently affecting the controls. You may also want to check if any of the front panel controls are stuck in a position by flicking them with a finger like tapping on a glass pane.
If there is no significant change, pls post back results and if you are considering a DIY (do-it-yourself). You would need familiarity with electronic circuitry and components.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 13, 2008
    Master:
    Sergeant:
  • 460 Answers
Dear sir, this problem on ur tv is due to a hardware problem likely to be a tuner card problem but it also looks like ur new to soldering and electronic terms so, we suggest u to take it to the service person to get it done not necesarily to the toshiba service centre a near by one... if it was a programming problem we cud give u solution on hand but this is hardware and different and involves risk factors on openning a television set.. And yes it is a internal component from mother board..
hoping to hear from u ...
Thankyou..
    Genius:
  • 1,847 Answers
The tv's tuner card seem to card the problem, replace the card it will work fine.
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Only yellow,blue & green colors, occas hint of red. What are correct settings? middle of gauge,
sounds like degausing circuits bad. unplug for couple of hours. if this doesnt work try waving a heavy magnet in front of tv about 2-3 inches from screen.
Jun 01, 2009 | Philips Magnavox MT1905B 19" TV
Max volume all the time and different menu
Have you tried taking the remote out of the room,or removing the batteries?Sticky remote keys can create havoc.I would do that first.
May 16, 2009 | Televison & Video
Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Sep 07, 2008 | Samsung LN-S4051D 40 in. LCD Television
Hitachi 42edt41green static
Dave you know your stuff man !!! You helped me fix my black line fix on my LCD / Plasma and then now you helped me get rid of my green dots on my screen !! You rock . thanks a Million
Aug 07, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Toshiba 32a33 32"tv
My dad and I fixed the TV/Video problem over the weekend using one of the solutions suggested. Make sure you stay away from the red wire running from the back of the tube to the circuit board.
1. Take the cover off the back of the TV.
2. On the bottom of the TV is a circuit board that is mounted on top of a plastic tray. Remove the cables running from the speakers by squeezing the tab on the white plug and pulling them up and off the board.
3. Looking at the back of the TV, pull the board+tray out (barely secured in there) and flip it 180 degrees so you're looking at the front of the board.
4. Desolder and remove the TV/Video push button. It's labeled on the PCB, and should be the second button in from the left.
5. Place the tray back in the TV and make sure the other buttons still remaining on the baord are aligned with the buttons on the front of the TV.
6. Put the cover back and you're done.
TV works as good as new again. Of course I can't use the TV/Video button on the TV itself, but the remote handles that fine. 20 minutes max, and no repairman needed.
Sep 06, 2007 | Toshiba 32A33 32" TV
Toshiba 32A33 32" TV Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
