Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag neptune MAH6500aww
This washer is about three years old and the only problem we have had up to this time is the replacement of the boot because it had been torn.
Now it will run fine until the rinse cycle where it runs down to 3 or 4 minutes and then will jump back up to 8 or ten minutes. It will not progress to the spin cyle. Any ideas on what the problem can be?
  • eflawrence Aug 13, 2008
    When my husband stops the machine and manually changes the control panel to spin, it does go to the spin cycle. It does not transition from rinse to spin. It just adds additional time to the rinse cycle.
  • 813 Answers
U have to with a good technician of dishwashers
Posted on Aug 13, 2008
    Master:
    Sergeant:
  • 462 Answers
This problem can be solved easier by calling a service men... because it involves opening up of control panels.. and other stuffs... which i think u will not be familiar with... also it involves electricity and water.. where both shdnt get in contact..
Thankyou
  • 3,037 Answers
Check your drain hose. Sounds like the washer drain hose is siphoning.
There should be a air gap at the end of the hose so it can not siphon.
Let me know what you find and whether this fixes it, otherwise I have a different idea.
  • Benjamin Patri
    Benjamin Patri Aug 13, 2008
    Did you actually check the hose or even try cleaning it?
    Genius:
  • 2,035 Answers
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Please use this link to order any pat of the washing machine:
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Good luck...
    Master:
  • 848 Answers
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
    If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Posted on Aug 13, 2008
    • gopinath pasupathy Aug 18, 2008
      there may be some problem with the circuit ..... thats the program not working properly .....
    What size washing machine is this
    Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
    Width : 27"
    Depth : 29"
    Height : 42 1/2"
    Capacity : 3.34 cu. ft.
    http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
    May 22, 2014 | Maytag Neptune MAH6500A Front Load Washer
    How do I check the drain pump on Maytag neptune washer
    I have a matag front load washer MAH6500AWW the door won't lock it just clicks
    Apr 07, 2012 | Maytag Neptune MAH5500B Front Load Washer
    Smelly clothes after washing. We have one of the models that was recalled for the same problem. Maytag Neptune - MAH6500AWW
    I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
    Jan 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
    I have a Maytag Neptune MAH6500AWW mOdel. Less
    YES YOU CAN , CONTACT PLUMBERS SUPPLIRES WITH MODEL NUMBER OF MACHINE AND MAKE FOR BERINGS WHEN YOU HAVE THEM YOU CAN START, FIRST MAKE SURE POWER IS OF THEN LOCATE SKREWS IN THE MACHINE PANEL, REMOVE AND OPEN PANEL LOCATE BEARINGS AND REMOVE BRACKET HOLDING THEM IN AND REPLACE NEW ONES , IF YOU OPEN MACHINE AND HAVE A GOOD LOOK YOU WILL FEEL MORE CONFIDENT, GOOD LUCK.
    Oct 22, 2009 | Washing Machines
    Maytag neptune modle MAH6500AWW
    it is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
    Apr 12, 2008 | Maytag Neptune MAH6500A Front Load Washer
    Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
    129 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
