Question about Canon Cameras
Turn the camera on, lens acts like it is going to project, camera turns itself off.
  • Canon Master
  • 43,501 Answers
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Posted on May 11, 2011
  • 20 Answers
I am not totally sure of the issue, but I have a few ideas.
First you might want to make sure the battery is fully charged. If the battery does not have enough juice then the camera will auto power off.
Second I would say that you should try to clean the outside of the lens. Make sure there are not any small pieces of dust or sand stuck in the cracks.
Hope that helps!
SOURCE:
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Camera wont turn on
your lens is not interacting with the power sequence if you turn turn on the camera and the message is displayed (switich the camera of and on again) then its mean that your camera lens is pressed either by your self or accidently the lens housing is malfanctioning
Feb 29, 2012 | Sanyo Xacti S650 Digital Camera
I have had my camera for about 4-5 years. It has worked great. lately it has started to act weird. when I turn it on the screen says access and wont let me take a picture. then after a few minutes the...
Go to camera Menu and select Initialize, OK.
Camera will turn on itself, if problem still exist, tap camera gently and turn On again to solve lens access problem.
Memory stick error can be solved by formatting it through Format menu in camera. Use another memory stick in camera to make sure that camera is OK.
Aug 12, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Dec 20, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Panasonic Lumix DMC-FX01 Less than 1 year old
same problem with ours, only 7 months old. We returned to the seller under warranty, and they fixed the problem FOC. They stated "lens adjustment" on the repair invoice.
I think these machines are not as sturdy as we are led to believe, and the slightest knock or bump sends them a bit squew wiffy!
Dec 02, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
