Question about Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier
IONIC BREEZE SI837
RECEIVED UNIT 8-12-08 AND PLUGGED IN FLASHING BLUE LIGHTS COMPANY OUT OF BUSINESS DID YOU FIND A SOLUTION
THANKS LOUIS
BLAZZERBOY@AOL.COM
  • 2,794 Answers
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Posted on Aug 27, 2008
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Is my Ionic Breeze Quadra hopelessly broken and beyond repair?
This unit can be replaced on ebay for around $45.00 which is under any labor cost to repair the unit you currently have. You can always post your unit for sale on ebay for parts.
Feb 19, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Professional Series Ionic Breeze Tabletop
Jul 29, 2008 | Sharper Image Professional Plus Ionic...
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Flashing lights on Model 1871
I wonder how many others are having this problem? It sounds like the wiring "went out" about the same time on all of these. Strange how it went bad just after the warranty ran out too. Something is fishy here. Planned obselescence? Anyone know a good attorney. Sounds like a good class action suit. I have two units. Bought them at the same time and both started flashing at the same time.
Nov 04, 2007 | Sharper Image Professional Plus Ionic...
Ionic breeze gp s1730
Ionic breeze gp s1730 I had the same issue. There are two switches in this unit. One closes if the back cover is on, the other closes when the removeable grid is in. My problem was with the later. Mine had corroded wire ends where it is soldered to the small circuit board where the switch is attached to. It also had a bad switch that did not close the circuit and I suspect internal corrosion as well.
Unplug the unit and remove the grid.
Remove the 4 small phillps screws from the front grill, remove front grill.
Remove 2 selector whells from top, remove four screws.
Test the switch function with ohm meter
Oct 20, 2007 | Sharper Image Professional Plus Ionic...
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
170 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
