Question about Epson Stylus C86 InkJet Printer
Canon pixma 3000 is not printing black properly. Have done deep clean and print alignment also removed print head and cleaned but to no avail. Some help eould be good. thanks. All cartriges are installed correctly and are full
  • ellyfithian Mar 29, 2009
    Printer cartridges are full, but black is not printing every line clearly, and the cyan is not printing on color prints.
  • john oxnard May 11, 2010
    Why is my Canon Pixma iP3000 printer only printing in yellow and not in black. Inks are all OK Thanks , John
  • 3 Answers
Do you want to buy rs 2007 gold?
Posted on Mar 06, 2013
    Problem Solver:
  • 7 Answers
It is very important to use a good quality ink, you can buy ink and toner for very cheap online and that would cause malfunctions in the printing process. visit sites like www.yahootoners.com to get the best quality ink at the best possible price.. you could also try cleaning your printer with a special type of cloth, here is a link to explain this in more deatails. http://www.ubergizmo.com/15/archives/2006/01/sticky_paper_for_printer_cleaning_by_elecom.html Tonerdude
Posted on Jun 04, 2009
Replaced black, would not print black, deep clean times two and still the same problem. What can I do?
Hi, the print head needs to be removed and washed with warm water, Please check the manual for print head removal and re-installation. Also print head alignment must be done on re-installation. The process sounds complicating but is quite simple. Do as if you are replacing a ink cartridge. When the print head is at centre in this process and stops.Switch power off on printer.Remove the cartridges, then remove the print head, wash in warm water carefully, do not use any brush or do hard rubbing, dab dry on paper towel. Replace print head into printer, then cartridges, then switch power on. Do print head alignment, clean print head once and print test pattern. Hope this helps as it has worked for me and is still working. All the best.
Mar 10, 2015 | Canon PIXMA MG5420 Inkjet Photo All-in-One
Printer has worked perfectly since purchased, suddenly started printing only the black portions of a photo. Did a nozzle check which confirmed only black cartridge functioning. Deep cleaned all heads....
The print head is still probably still partially blocked. Cleaning/deep cleaning tries to clear the head by flushing ink through, doesn't always work but does use up your ink.
You can get print head cleaning kits, PC shops,ebay etc. Try one of those.
Here's a really useful ebay url. with some youtube links, if you run the second video down you should get a pretty good idea.
http://www.ebay.co.uk/itm/Printer-Print-Head-Printhead-Cleaning-kit-Epson-Canon-/130479422758?pt=UK_Computing_Printer_Paper_Accessories_ET&hash=item1e612dfd26
Here's a direct link :- http://www.printheadhospital.co.uk/quickshop/
You don't have to buy this one, there may be cheaper, have a shop around.
Aug 27, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I've changed printer cartridges but it is not printing a thing. Not a test print, not print head alignment nothing. I've done the clean the deep clean print head alignment and there is still no ink coming...
Please check the seating of ink cartridge. when you replaced it, it should make a little click sound confirming that the ink cartridge has seated properly. Please repeat the process once more. Also when you remove the ink cartridge check if the thin strip on the ink pad has been removed. If not then remove it before fixing it again.
Jan 11, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Cannon Pixma IP3000
Error 6A00 is a printer sheet feed unit error.
You need to send into repair in any canon autorized service center.
Just let me know if you need further assistant
pincer
Apr 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip1000
as you are telling the problem is inside your printer.please get it serviced.
Apr 05, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Epson Stylus C86 InkJet Printer Logo
223 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
