Question about Frigidaire ATF6000ES Front Load Washer
Frontload washer when I push start only thing run is drain pump but not draing
  • 1 more comment
  • sharifai Aug 13, 2008
    no, I won't get any error message.
    No, I won't get any error messages.
  • Gayle Ashbach
    Gayle Ashbach May 11, 2010
    Do you get an error message?
  • 876 Answers
This could be the correct solution. It does sound like the drain is plugged, but my washer generally shows an error message number. I will continue to look for an answer also, in case this does not work.
Posted on Aug 13, 2008
    Sergeant:
  • 243 Answers
Check to make sure the drain pump is not clogged in any way.
also does the washer fill up and everything else and just does not drain?
if that is the case then best bet is to try and change the drain pump. if you are unable to do it yourself i recommend calling a qualified service professional to come out and take a look and make a proper diagnosis for a repair.
thanks,
Nate
  • 725 Answers
You have a plugged drain pump.. remove the back .remove drain hoses remove drain pump and check for something in the pump... you may find coins or bra wires... hope it helps
SOURCE:
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Maytag top washer not draining
You will need to replace the drain pump. What is the model number?
Aug 13, 2012 | Maytag Washing Machines
What does 5d mean when it comes up on the washer
5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of excess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle.
Feb 28, 2011 | Kenmore Washing Machines
My washer started just find, then have way through the wash it stoped dispensing water and will not drain. Tried spin cycle only, and nothing. Tried unpluging, and still same problem Tried restarting...
all frontloaders have to start the drain pump before any cycle will start ... if there is something stuck in drain pump or hose between bottom of wash tub to pump washer will not spin... check filter pump assymbley and drain pump
Jan 24, 2011 | Frigidaire Washing Machines
Will not rinse and spin Very tempramental Have drained cleaned both filters
for any frontload washer to drain and spin two things must happen first doolock mechanism must lock and drain pump must start draining before anycycle can beging . what about checking for blockage between tub bootom hose to pump squeese hose with hand to feel any blockages to pump if no blockages replace pump. I beleive u need to replace your drainpump.
Jan 23, 2011 | LG WM-2277HW Front Load Washer
My kenmore elite frontloader washer will stop 2-4 times during a regular wash with a flashing F02. I have to push cancel and then start again and it resumes the wash. I also have the suds light come on...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
E20 Error sign
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
May 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Code 5d comes on and it stops running
5d means the follow; possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
ERROR CODE F33 AND 5D
5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. F33 MUST be fix by a technition Service ONLY am sorry about this inconvenient. "Was this helpful?"
Frigidaire ATF6000ES Front Load Washer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
