Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
LCD repair/replacement? Any idea what typical cost is for new LCD? For the cable connection suggested by Sweet Rascal? And give me an idea of frequency of this problem? Did anything I did in picture taking cause it? Better to send it in to Casio, or use some local service? (I have no idea how long it will be out of service by sending it in...)
If you're handy enough, you can try replacing the screen yourself. A supplier is selling replacement LCD screens for the Z750/Z850 for around $60 (shipping included). I also found on youtube a video of someone performing the actual replacement http://www.youtube.com/watch?v=FVMzSvI2G-w. If you haven;t purchased a rnew camera already, checkout whether buying a another camera would be more cost effective than forking over 60 bucks to fix it yourself.
Posted on Sep 07, 2008
    Sergeant:
    Champion:
  • 248 Answers
Almost as much as a new cam...you browse web for this problem and youll see that there are a lot of you with the same problem. most of them just buy new cams.this is an equipment malfuntion.
it woul take a 2 weeks to a month
Posted on Aug 13, 2008
My telefunken Vegas has a crack on the lcd model VPM-420FHDISerialnmr062010552 FHDI hw much will it cost me to repair it pls
you would be better off replacing the 42 inch TV rather than repairing it. Suggest you shop around for a new TV. Cost for a new 42 inch as a guess would be between 300 to 500 dollars. Good luck. Invest in a smart tv.
Nov 19, 2015 | Televison & Video
3 wheel rascal 600 blinks 4 - 8 times...what does it mean?
Good day to you.These series or blinks or bleeps are codes to determine the fault.& the trouble you will find is Shoprider etc will not give out info to the public.Contacting a Scooter repair shop is a good idea,reason being.They can order your part if needed.You can also download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as a PDF File,if you do anything yourself.Remember a repair shop will be hesitant to even look at it & I suggest you take a photo of every step if fixing yourself with your mobile.Have a nice day,hope I was of help.Colin
Mar 31, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Blank screen on my dv9608ca laptop i changed power inverter and screen its very dark can faintly see desk top items. everything works when in connect to different monitor so can it still be video card
It sounds like your laptop's Back Light is out. The screen has two layers, the LCD display, which provides the image, and the back light, which gives it brightness and clarity. Unfortunately, it is no easy fix and typically costs more than a new laptop to replace. I'd recommend calling HP themselves if you want to get it repaired.
Aug 26, 2011 | HP Pavilion dv9608ca PC Notebook
PV-DC152D CAMCORDER, LCD Display only works if it is pulled out, turned 180 degrees and pushed back into place so the display is facing you. If you move the LCD display over 3/4" away from camcorder...
The most likely problem is a cracked ribbon cable that goes between the camera and the display. The cable needs to be replaced. Typical cost for this is around $40 or so plus labor. I would not suggest that you attempt this repair yourself as opening up these units is not easy without experience. Also, there are cables that can be damaged if opened incorrectly.
Dan
Apr 21, 2011 | Panasonic Cameras
My kodak easyshare c603 has a deffect in lcd where can i get the lcd to be replace ?
Repair cost is too much. Do it yourself.
Buy a used camera (one sold for parts) from EBAY.com. You may be able to get it very cheap. Then replace the LCD from the one you bought to your old one. A new LCD screen from shop will be expensive. I wont advice you to get a new one.
The only tool you need a small screwdriver set (buy it for $1 from Dollar store). Remove the camera cover by removing 5-6 screws. Once the cover is removed, LCD is accessible. The LCD cable is connected through a connector to the main board. There is a pressure plate in the connector, simply lift it and pull the cable out and remove your LCD. That simple. Replace in the reverse order.
Two sites to give you step by step directions:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Jan 13, 2011 | Kodak EasyShare C603 Digital Camera
52" LCD FULL HD TV screen is cracked doesnt give any picture
Unfortunatly, no.. You will end up spending more on the repair then the cost of a new tv typically.
Sep 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volvo V70 t5 Shift to Transmission cable broken
Seems excessive for just a cable unless the transmission has to be removed and dismantled.
I suggest you check with the dealer for costs and parts availability and the dealer price would typically be the most expensive quote for your guidance.
Then you should ask at least a couple of local transmission specialists who would typically be 30 - 40% cheaper.
Jun 01, 2017 | 2001 Volvo V70
Ipod nano
Hey funnydrake,
Unfortunately, if the iPod doesn't turn on after being left in an "extreme temperature" environment, you may need to seek assistance through a factory-authorized repair facility.
When electronic devices are left exposed in vehicles on hot days, the excess heat can not only cause electrical shorts but may also damage sensitive components like the LCD screen. Many electrical shorts can be resolved by replacing internal cables or resoldering connections, but larger defects (such as damage to LCD screens) can often prove cost-prohibitive to repair.
If you're unsure what to do next, I would strongly suggest contacting Apple's toll-free hotline (800-275-2273) for more information. Most manufacturers are able to give consumers a good idea of what is covered by their factory warranty, and provide repair estimates if necessary.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 11, 2008 | Apple iPod nano
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
93 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
