Question about NEC DTH-8D-1 Corded Phone
NEC DTU-8D wiping the directory list
I have inherited a phone in my office and it has a lot of numbers stored in memory.
How can I wipe the directory listings so I can start again?
  • Isaiah James May 11, 2010
    Are you referring to the voice mail directory or the speed dial directory?
    Problem Solver:
  • 14 Answers
If it is in the system speed dial directory you have to go one by one and type "Feature, Redial, bin # where it is stored (system 00~79, station 80~99), Feature". This should wipe each Speed Dial listing.
If it is in the voice mail unit you may want to go phone by phone and log into the box. You will need to redo the following:
Personal Greeting
Recorded Name
Spelled Name
Directory Listing
Security Code
All these options are listed in each mailbox through a series of soft keys. Let me know if you need more info.
Posted on Nov 11, 2009
NEC DTU 8D-2 Corded Phone how do I page?
Standard codes run from 50 to 59. Internal 1,2,3,all, external 1,2,3, all, all internal and external. That's if your codes are at default, and your system is a Pro II, Elite, or IPK. Those phones work on about 8 NEC systems.
Mar 11, 2014 | NEC DTU 8D-2 Corded Phone
How to access voice mail or record greeting on NEC DTU 8D-2 Corded Phone
If I'm not mistaking, you need a NEC PBX to work with that phone. In which case you need to contact your telecom helpdesk to find out what the voicemail phone number is so you can set that up.
I could be wrong about the phone
Jun 15, 2012 | NEC DTU 8D-2 Corded Phone
Change Extensions on NEC IDK Phone?
It is easier to move the wires but if you know how to go into programming than change the extension numbers on the ports in mb 4-10
Apr 28, 2009 | NEC DTU 8D-2 Corded Phone
I have a 4 line NEC Dterm 80 phone. How do I recall the past
depends on the type pf system. Do you have a coib installed in the system? Is caller id setup or programmed? If there is no mif card in the switch you cannot save caller id info. It only shows up when the phone rings and while on the call. There should be a directory key that you can price to scroll through the numbers if everything above is correct. ldtsnj.com
Dec 31, 2008 | NEC DTU 8D-2 Corded Phone
Caller ID Scroll
Your system needs to have a mif-m card and kmm chip installed and all programming setup in order to scroll through the caller id. If this is all setup you can hit the directory button and than use the arrow buttons under the display to scroll. ldtsnj.com
Oct 30, 2008 | NEC DTU 8D-2 Corded Phone
Re: storing contacts name/number
feature redial dial 00-19 for the memory location than dial a 1 than dial 9 and the full phone number than press feature to save it. If you have softkeys at the top of the phone(display) hit sta or sys to see the number you stored than pickup the receiver or hit speaker to dial the number.
Sep 04, 2008 | NEC DTU 8D-2 Corded Phone
How Can I check voice mail remotely
Do you mean check your v/m for your extension from somewhere other than your office by calling in?
If so, it would depend on how calls are answered at your office. If someone answers, have them transfer you to the ext number for VM. If you have an auto-attendant, or a DID directed to your extension, call and wait 'til VM answers.
Assuming the default settings are in place, dial "9" + your ext number, then your security code if you have one.
Mar 31, 2008 | NEC DTU 8D-2 Corded Phone
Caller ID Display
This one could have different variables.
  1. your CO lines must have CID
  2. your CO card in the system must have CID capability
  3. older systems have a limited number of extensions that can display CID (16)
  4. your ext must be set to ring.
NEC DTU-8D-1A TELEPHONE
Press Feature 1 That will turn the mic off, or on.
Oct 23, 2007 | NEC Electra Elite 32D-1 Corded Phone
NEC DTH-8D-1 Corded Phone Logo
331 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
