Question about Vizio GV42L 42 in. LCD Television
My Vizio doesn't power up or turn ON, Neither by the remote nor touching the power surge button.
Doc
  • mkristyt22 Aug 22, 2008
    I have the 37 inch Vizio same thing...won't turn on or power up with remote or buttons....no clue what to do. is i returnable? I have two of them we barely use this one and its not working...its only been 8 months
  • caseysobe Oct 06, 2008
    I have a 42' vizio. It has been working great for almost a year. Just this morning it won't power up with remote or on the TV. The Vizio logo stays lit white as if it were powered on. Vizio is not being helpful and says it is no longer under warranty. Any solution?
    Problem Solver:
  • 4 Answers
May be a bad power supply, which is a common problem with these units.I have a GV42L 42" manufactured in march 2007. It works perfect except the screen has a fracture on it. The warranty is voided because we damaged the screen. I can sell this to somone who has a good screen but needs boards or speakers, etc. Or I will buy your tv that has a good screen but damaged boards in it.
camckay7626@yahoo.com
Posted on Sep 06, 2008
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
The tv will not turn on and smells like something burned up ..may have had a power surge
The power unit needs to be checked and/or changed. Please refer to a professional service center because you could die trying this yourself (the risk of electrical shock is very big).
Jan 18, 2011 | Vizio GV42L 42 in. LCD Television
How do you switch to cable without remote
On the Unit itself, are Buttons, up to seven, 7, of them, usually, ON/OFF, MENU, Channel Up, Down, Volume Up, Down, SELECT/ENTER, Nearly ALL functions available on the remote can be performed via the buttons on the TV. Simply choose menu, and Step through with the Channel & Volume keys, and "Selecting" with the select/enter key. www.scribd.com/doc/.../VIZIO-GV42L-HDTV-Service-Manual
static.compusa.com/pdf/GV42L_HDTV_User_Manual.pdf - United States
Above are your User manual, above that is a service manual.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
I cannot access the closed caption feature on my Vizio VO42L help?
Look at the remote control: (page 14 of the user manual)
CC
/Stop – This button will select the Closed Caption mode. The
options are OFF, CC1, CC2, CC3, CC4, TEXT1, TEXT2, TEXT3 OR
TEXT4. Additionally, this button stops the CD, DVD or VCR when the
component is activated with the remote control.
Download user manual here:
http://tv.manualsonline.com/manuals/mfg/vizio/gv42l.html
Please post back what you find.
Nov 15, 2009 | Vizio GV42L 42 in. LCD Television
Power surge and now TV will not turn on.
Looks like you may be in for a new TV. Next time, get a surge protector.
Oct 19, 2009 | Vizio GV42L 42 in. LCD Television
Vizio won't turn off
This could be a mainboard problem. Sometimes one of the fuses may be bad and may freeze up causing the TV to not be able to power off.
Mar 31, 2009 | Vizio GV42L 42 in. LCD Television
VIZIO GV4VL cuts off the bottom of screen
on the tv's remote you have a button which says one of a couple things. 1) pic size 2) ratio 3) zoom 4) aspect. using that button push it a couple of times until you get to either 16x9 or full depending on the brand of tv you have
Jan 21, 2009 | Vizio GV42L 42 in. LCD Television
42 Vizio LCD Tv-
Replace the power supply will fix the problem. Is the Vizio LED light on?
Jan 19, 2009 | Vizio GV42L 42 in. LCD Television
When i turn on y Vizio LCD TV theres a blue screen that says no
Your TV is probably in RGB mode which means its looking for a computer signal. Plug a computer into your TV and then it will stay on. Then you can change it back to TV mode.
Dec 24, 2008 | Vizio GV42L 42 in. LCD Television
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Vizio GV42L 42 in. LCD Television Logo
545 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
