I have a Philips 5425 Philishave. It has worked wonderfully well for years. At the moment it is not cutting well. The blade retainer is not connecting well, and the heads are spinning freely, with a screeching sound being made. I would appreciate some advice on how to get it back to working order. Thanks, Frey.
  • Anonymous Nov 24, 2008
    I encountered exactly the same problem. After many years I wanted to clean it well with the same results mentioned. No replacement part available except for the blades which arent the problem. The only solution: Buy a new one. Now I got a rechargeable Philishave which is very handy, but still it is painful buying a new one although te old one worked well...
    Robert
SOURCE: OFF AND ON SWITCH DOES NOT WORK for Philips Philishave HQ7850
Hopefully you discovered it's not difficult to take the shaver apart--at least if it's like mine.
Two screws on the back hold it together--one visible, one under the flip trimmer. They have odd slots but can be undone with a small slot screwdriver, though I think the proper way is with a torxx.
Once you undo the screws, take off the metal clips that hold in the batteries and serve as the screw holes. The batteries can be flipped up carefully (so as not to break the copper wires to the motor).
If your problem is like mine, you'll see a clear plastic piece that has dislodged from under the rubber push switch. Place the round end so that it lays in the rubber dome and contacts the switch.
You can flip the batteries back down in their proper position at this point and test to see if the plastic part is seated properly.
Then simply put the metal clips back and replace the screws. Amazingly simple. Hope that helps.
Posted on Aug 08, 2008
  • 10865 Answers
SOURCE: crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Posted on Jan 28, 2009
SOURCE: philips voip 841: no sound on skype calls, but fixed line works f
We have had this issue recently as well with both our parents and now our own.phone.
Simple solve I found here:
1. Remove batterys
2. unplug base
3. replug in base
4. Put batteries back in
Worked for us - must be a virus or something
Posted on Apr 21, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my amana dryer model is making screeching sound
Hi Peggy...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. BE REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 30, 2009
  • 351 Answers
SOURCE: Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
Posted on May 04, 2010
Testimonial: "Great feedback! thanks! "
I need to know where I can buy Philishave Blades for Type HP1336 - Model 55008? In Ontario, Canada.
You can buy blades for model HP1336 from shaveroutlet.com and have them shipped to you Canada. The item is found at the link below
http://shaveroutlet.com/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
Mar 02, 2015 | Health & Beauty
How to get replacement heads for philishave cool skin HQ6761
Compatible blades can be found at shaveroutlet.com using the link below
http://shaveroutlet.com/philips-norelco-hq7-gentlecut-shaving-heads.html
Jun 28, 2014 | Philips Philishave Cool Skin HQ6760/HQ...
Philishave t788
Ciao, ho visto un tuo vecchio annuncio Re: "Philishave t788 The motor is running, but thr blades are not moving". Lo hai ancora? Mi manderesti una foto dell'oggetto? Grazie! viatrento@gmail.com
Oct 04, 2013 | Philips Health & Beauty
Replacement blades
In the UK, Philips norelco HQ56 replacement heads for philips philishave HQ5812 electric shaver blades replacement parts.
philips HQ56 replacement heads UK
Aug 23, 2013 | Philips Philishave HQ5812 Electric Shaver
Blade head assembly for Philishave 925
Replacement heads for model HS925 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters/philips-norelco/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
Mar 21, 2013 | Health & Beauty
Trying to buy new blades for philishave HQ5812 but cant find any do you have any suggestions?
Usually they make this Philips so when the blade wears out you are force to buy a new equipment once again, I was looking for the blades by itself but can't find it
Thanks
Jun 03, 2011 | Philips Philishave HQ5812 Electric Shaver
I require new cutting blades for my philishave4000 modelHQ4401
philips norelco HQ56 replacement heads for philipshave 4000 model hq4401 blades replacement parts.
Aug 26, 2010 | Philips Philishave Micro Action HQ 4806...
Hi the shaver isnt cutting as good as it should do i need new cutting folis or new cuttting blades? which eather where can i get them from? Many thanks Donna
Philips suggests that the heads be changed every 12 months. If they are 12 months olor older and no longer cut well, they probably need replacing. You will fin replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq6-quadra-action-replacement-heads-p-250.html
Jun 20, 2010 | Philips Philishave HQ7850 Electric Shaver
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
