Question about AMD (WBK38) CPU Fan
CPU Fan not running
How can I tell if my CPU fan is not running. I do not hear the familiar noise. Is there something I can do before I call someone to fix it. I have never opened up a computer so I am a little intimidated.
  • 5,568 Answers
If the system is a couple of years old, the fan may be clogged with dust so the blade can't turn; these little suckers don't have much torque.
You can find the little fan pretty easy since (unless you have a high-end video or sound card) it will be the only one actually on the system board.
If you know how to access the BIOS on your particular computer, you may have one that monitors the CPU temperature and tells you in degrees.
Watch the screen at bootup for a message about entering 'Setup.'
This will give you the key to press and it often must be done very quickly; it's often F1 or F2.
Some BIOS will call the function Advanced or System something.
Don't make any changes you don't understand and when you exit, don't 'Save' any changes.
Posted on Aug 13, 2008
Fan runs constantly on hp pavilion a1530n
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
First clean your computer of dust you could use a fine air blower from a compressor or a can of compressed air whatever you use make absolutely sure there is no moisture in the airlines
if the fan in your computer is constantly running to cool down the cpu and it is normal for it to increase it's speed, your fan should run quietly even it increases the rpm.
But if you hear a loud noise in the fan, i think there's something wrong with it.
I suggest for you to check the fan if it's coming in contact with anything. If the fan is visible while your computer is operating, you can observe it to know what is really happening.
I don't know what type of fan hp uses on their computers, maybe something is loose already on the fan so better check it or bring it to an hp service center.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
make sure your CPU has thermal paste
your CPU might be getting hot making you computers fan to run consistently
hope this helps
Aug 14, 2012 | HP Pavilion a1530n PC Desktop
Fan running continuously
the fan in your computer is constantly running to cool down the cpu and it is normal for it to increase it's speed, your fan should run quietly even it increases the rpm. But if you hear a loud noise in the fan, i think there's something wrong with it. I suggest for you to check the fan if it's coming in contact with anything. If the fan is visible while your laptop is operating, you can observe it to know what is really happening. I don't know what type of fan hp uses on their laptops, maybe something is loose already on the fan so better check it or bring it to a service center.
Aug 06, 2012 | Computers & Internet
I hear a knocking noise when i turn on the heat or ac
It sounds like you have something in your blower motor/fan housing that's hitting the fan when it's running. Something may have fallen down the defrost vents on the dash. Or, a bad bearing in the blower motor. Either way, the blower motor would have to be removed. Sorry, but I'm not familiar enough with that model to tell you how to do it.
Jul 12, 2011 | 2008 Chevrolet Impala
I have an IBM x346 eserver that has run well for years. The fans are now very load (whirling noise). I typically only hear this noise when the room temp is high, but this server is in a cool room with no...
It sound like the CPU fan or server case fan/s or power supply fan bearings are worn.
To determine which fan/s is faulty open the computer case and stop each fan from spinning, one at a time to determine the noisy fan. Once you have identified the noisy fan then replace that fan.
Feb 07, 2011 | IBM xSeries 346 Server
I have problem on my desktop pc. noise comming from motherboard. if you have any idieas please tell me. thank you
Noise coming from the motherboard is likely a fan or something mechanical on the processor, I would guess.
Normally, motherboards make no sounds, except maybe a beep if there is a fatal error, but that's due to incompatible components plugged in to the motherboard, or burnt out components on the motherboard.
Jan 02, 2011 | AcerPower PC Desktop
Cooling fan makes loud noise upon starting machine, its not even a year old
Open the side panel of the computer. The inside of your eMachine must be like this:
The only fans in the case are the one inside the power supply and the one over the cpu heatsink. Take a look for something like cable or tire-up to come too close at the cpu fan. In this case take away this cable or tire-up and keep it in a safe distance. Try the results. If the problem is still active try this tip very carefully. Use a drinking straw as brake for the cpu fan. Hear the difference in noise. If the noise is dissapeared your cpu blower needs replacement. KEEP IN MIND THAT YOU MUST NOT RUN THE PC WITHOUT CPU FAN FOR MORE THAN 5 SECONDS. OTHERWISE YOUR CPU WILL BURNED.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 02, 2010 | E-Machines eMachines T3830 PC Desktop
Noise from unknown source
Grrrrrrr - Could be CD running, Could be Fan on the CPU, which if not fixed will kill you main chip, could be power supply fan, check in the back and see if fan is turning consistanly ( I think that is how you spell that) If you know how to remove covers, take side off and look at fan on the CPU or other fans and when you hear the Grrrrrrr se if you can tell where it is comong fro, also some hard drives will make a sound as they get older.. Good luck....
Apr 23, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Sony vaio cpu is makes a lot of noise
im not 100% sure nut i think its the power supply cause some power supplys are very noisy and it might be why the cpu is overheating
Aug 09, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
AMD (WBK38) CPU Fan Logo
1,346 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
