Bunn A10 Coffee Maker
Problem for Bunn A10 Coffee Maker
Problem with a Bunn STPF-15
By dsousa7777 on Aug 13, 2008
When I plug in my machine the water starts coming out and never stops. Something is nor closing or telling it to close. If I unplug it and plug it back in it will stop but then start again. please help.Dennis
Comments:
Aug 13, 2008
- This machine is a Bunn STPF-15.
Solution #1
posted on Feb 11, 2009
Not Rated)
furnoptn
Rank: Guru
Rating: 89%, 71 votes
This problem can be caused by either the solonoid or the flow control board. The easiest way to find out which one is causing it is to leave your brewer unplugged, unplug one wire off of the solonoid and plug your brewer back in. if it still does it, replace the solonoid valve. If it doesn't, replace yor control board. The solonoid should be under the front cover of your brewer, and is silver with 2 wires coming to it. The control board is located at the back of your brewer. Take careful note of where the wires are on that board, though, so you can put them back in the same place. I find the best way is to leave the wires on the old board, and replace them one by one to the new board, or if that is not possible, making a picture showing their placement is helpful.
Was this helpful?
Yes
No
Popular Solutions for Bunn A10 Coffee Maker
Questions and Unsolved Problems for Bunn A10 Coffee Maker
Do you recommend Bunn A10 Coffee Maker?
Answer
Answer
pump not working, no pumping water
Answer
need filter for coffee maker can't find local suplier in victoria bc
Answer
water leaks out from under plastic tank when brewing,there are two small holes in bottom of plastic... (More)
Answer
my bunn leaks water, how can i fix this problem?
Answer
Coffee maker will not stay hot, it goes to warm. It is the housing where the heat has diminished,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , OH
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
