Question about Volfenhag ZX-8200 Car Audio Amplifier
Protection Light coming on with loud volume and power
I got this Volfenhag ZX-8200 a few years ago and has always worked fine until a few months ago. When I turn up the power to make the bass hit hard it goes out and the protection light comes on. That is when the engine is running.
However, when just the radio is on (engine is off), the amp runs fine and I don't understand why that is. I know the volts going to the amp goes from 12 V (engine off) to 14 V (engine on) so that is my only guess. Do you know what might be the problem? Is the engine consuming to much power when it is on?
  • 631 Answers
It's most likely that the over-current protection is tripping at high power. At lower voltage, the amplifier can't produce as much output power and therefore can't produce enough current to trip the protection circuit.
You need to check your speakers to make sure that they are not shorted. With an ohm meter, the resistance across the voice coil shouldn't read any less than ~90% of the rated impedance.
If the speakers and the wiring are OK, the amp may have an internal fault causing the amp to go into protection.
Let me know if you have any other questions.
Posted on Aug 13, 2008
Brand new volfenhag 15 1500 wattsblew on 1200 watt amp why
There are a couple of reasons why this might have happened. Subwoofers are finicky. I always recommend to my clients that you don't apply full power to your sub until you have had one week of playing it at low volume. This helps to condition the voice coil. When at full power the voice coils heat up rapidly. To go from cold to heat fast will warp the coil. The bad news is that this would fall under the "abuse" category for refunds. Then again, you might get lucky with a return unless you bought it from an individual. The other thing might be how it was wired. If your amp is 4 ohm stable and you wired to a 2 ohm load, it may have shorted something. But you would think that would be the amp. Not sure this answered the question, but just a few ideas to think about.
Aug 16, 2011 | Volfenhag ZX-4715 Car Mid-Range
The red protect light comes on, i dont know how to make it go green so it will work. please help!!
Devices with several light emitting indicators would each display as observation of manufacturers installed features. Red indication is power cciuit indication, yelow as alternate warning where green is indication of regular fucntionality. Once the device is least malfunct, every light is an equal expectation. Usually with amplifeiers, the red light has to be on throughout until stereo became powered on to porduce green light effects as radio expectations.
Feb 14, 2011 | Volfenhag ZX-8200 Car Audio Amplifier
Volfenhag zx 8200 amplifier cooling fan not working
open the back of your amp and see if the leads from the fan are burnt anywhere. trace them from the fan to where they are soldered into the board. if the wires appear to be fine, then test them using a volt meter. if the positive is not recieveing power you may want to solder the lead to your remote turn on.
Aug 24, 2010 | Volfenhag ZX-8200 Car Audio Amplifier
How to switch protection off (red LED to blue)
The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
I have a volfenhag zx-8400 and it just geos into protection mode
The most likely problem would be a blown fuse. I would replace all of the fuses.
Oct 04, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Need help please...
If you unplugged the fuses, the amp won't come on at all. I'd say its a blown transistor, you can test this by opening up the amp and using a multimeter to check resistance on the transistors.
Aug 03, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Protect light
check speaker wire is not grounded and/or the proper impedence is followed. Those amplifiers are 2 ohm stereo stable. Know the difference.
Remove speaker wires and try amplifier.
Add 1 speaker at a time until the problem recreates itself, or test them with an ohm meter.
Dec 20, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Protection light
It's likely that there are shorted output transistors in at least one channel. If you want to repair it yourself, you'd have to determine which transistors are defective and replace them. The following page will help guide you through the basic troubleshooting.
Basic Amplifier Repair Primer
Jun 10, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Amp protection light
is the amp well grounded run a wire from amp hosing to metal of car hope it work cheers
Jan 15, 2008 | Volfenhag ZX-7180 Car Audio Amplifier
Volfenhag ZX-8200 Car Audio Amplifier Logo
150 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
