Cars & Trucks Logo
Posted on May 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove the radiator? - Sable Mercury Cars & Trucks
robert DIBBLE
Level 3:
Master:
  • Master 448 Answers
  • Posted on May 10, 2011
robert DIBBLE
Master
Level 3:
Master:
Answers
448
Questions
0
Helped
132892
Points
1293
First thing drain the antifreeze remove the upper and lower hoses if automatic you will
need a 1/2 tubing wrench loosen them up and move them out of the way a (LITTLE)
don't bend them take the screws out of the shroud.
if you have a mechanical fan you need a fan wrench you can rent one from auto zone for
a few bucks ///// if electric fan it will be part of the shroud
you will pull the shroud and radiator out together
done deal
hope this helps you
good luck
bob
How to remove radiator on 2000 Lincoln Continental
RADIATOR
Removal
1. Disconnect battery ground cable.
2. Drain engine cooling system as described.
3. Remove engine air cleaner.
4. Remove upper radiator hose from water bypass tube.
5. Remove radiator overflow hose from radiator and fan shroud.
6. Remove transmission oil cooler line from oil cooler inlet fitting.
7. Remove nuts retaining A/C condenser core to the radiator.
8. Disconnect engine control sensor wiring from the auxiliary electric cooling fan motors and the CCRM.
9. Raise vehicle on hoist.
10. Remove splash shield from lower radiator support and front sub-frame.
11. Remove lower radiator hose from radiator.
12. Remove oil transmission cooler line from oil cooler outlet fitting on radiator.
13. Remove retaining screws for power steering/transaxle oil cooler and position cooler aside.
14. Support fan shroud, radiator and A/C condenser core with a suitable jackstand. Remove lower radiator
support.
15. Position jackstand aside and carefully remove radiator and fan shroud.
16. Remove two retaining bolts for fan shroud at top of radiator and remove fan shroud from radiator.
17. Remove upper radiator hose from radiator.
NOTE: Loosen transmission oil cooler lines while securely holding radiator
connector with a back-up wrench.
18. Remove the radiator.
How do I remove my radiator from my 2000 Lincolncontinental
  1. Disconnect the negative battery cable.
  2. Drain the engine cooling system.
  4. Remove the upper radiator hose from the water bypass tube.
  5. Remove the upper radiator supports.
  6. Remove the radiator overflow hose from the radiator.
7.Remove the upper radiator hose and two clips from the fan shroud.
8. Remove the transmission fluid cooler lines from the fluid cooler inlet and outlet fittings.
9. Disconnect the engine control sensor wiring from the auxiliary electric cooling fan motor.
NOTE
Support the A/C condenser core and bracket.
10. Remove the nuts retaining A/C condenser core to the radiator.
11. Raise the vehicle on a hoist.
12. Remove the radiator air deflector.
26003867-whqtqzmdhjettns5tbwoqqce-3-3.gif 13. Remove the lower radiator hose (8286) from the radiator.
14. Remove the bumper cover pin-type retainers.
15 .Remove the power steering/transmission fluid cooler and position the cooler aside.
16. Support the fan shroud, radiator and the radiator support.
17. Remove the bolts and the left side radiator support.
18. Remove the bolts and the right side radiator support.
19. Lower and remove the fan shroud, radiator and the radiator support from the vehicle.
20. Remove the upper radiator hose from radiator.
21. Remove the two bolts and the fan shroud from the radiator.
22. Installation is the reverse of the removal procedure.
How do I change the radiator on a 96 lincoln contiental 32v intech V8 ?
RADIATOR
Removal
support.
18. Remove Radiator
Change out cooling system radiator
RADIATOR
REMOVAL 1) Disconnect negative cable from battery. 2) Discharge the A/C system. 3) Remove the front fascia.
WARNING: DO NOT REMOVE THE CYLINDER BLOCK PLUG OR THE RADIATOR DRAINCOCK WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR. 4) Drain the cooling system. 5) Disconnect the radiator fan electrical connectors. 6) Disconnect coolant reserve/recovery hose. 7) Remove A/C lines. 8) Remove the auxiliary transmission cooler hoses. 9) Remove the pushpins and the upper radiator seal.
10) Remove the pushpins and the LH and RH radiator seal (Fig. 20).
11) Remove the A/C condenser side brackets to radiator attaching screws (Fig. 22). Separate the condenser from the radiator by lifting upward to disengage from lower mounts (Fig. 22). Allow the condenser to rest in front of radiator. 12) Remove the upper and lower radiator hoses.
13) Radiator can now be lifted free from engine compartment. Care should be taken not to damage radiator cooling fins or water tubes during removal. (Fig. 21) 14) Remove the auxiliary transmission from the radiator module. 15) Remove the cooling fan assembly from the radiator module. INSTALLATION
1) Install A/C condenser, (if removed). 2) Install radiator fan assemble, if removed. 3) Install auxiliary transmission cooler, if removed. 4) Slide radiator down into position. Seat the radiator with the rubber isolators into the mounting holes provided, with a 10 lbs. force. 5) Install mounting screws. 6) Connect the cooling fan electrical connector. 7) Install the radiator upper and lower hoses 8) In the LH and RH radiator seals. 9) Install the upper radiator seal. 10) Install the auxiliary transmission cooler hoses. 11) Connect the coolant reserve/recovery hose. 12) Install the front fascia. 13) Fill the cooling system. 14) Connect negative cable to battery
2helpful
How do i remove a radiator from a 2002 jaguar typex
FIRST YOU DRAIN OUT THE COOLANT SYSTEM.DRAIN THE EXPANSION TANK REMOVE EXPANSION TANK HOSES FROM RADIATOR.REMOVE COOLING FAN MOTOR AND SHROUD.REMOVE UPPER RADIATOR HOSE, REMOVE RADIATOR LOWER COOLANT HOSE. REMOVE CONDENSOR TO RADIATOR MOUNTING BOLTS.DISCONNECT TRANSMISSION COOLER LINES FROM RADIATOR.REMOVE RADIATOR SUPPORT RELEASE CLIPS OR BOLTS MOUNTING FIXTURE. THEN REMOVE THE RADIATOR.
3helpful
How do i remove radiator fan from my 2004 pt cruiser?
Hope this helps!
Removal & Installation
NOTE The fan motor, fan, and the shroud are serviced as an assembly.
CAUTION Do not open the radiator draincock with the system hot and under pressure, because serious burns from coolant can occur.
  1. Disconnect negative cable from battery.
  2. Remove battery and battery tray.
  3. Drain cooling system below upper radiator hose level.
  4. Remove grille.
  5. Remove upper radiator closure panel and center brace.
  6. Disconnect upper radiator hose from radiator.
  7. For turbocharger equipped vehicles: Remove radiator inlet neck.
  8. Hoist vehicle.
  9. Disconnect radiator fan electrical connector (.
  10. Remove the two lower and left side radiator fan screws and.
  11. Lower vehicle and remove the remaining radiator fan attaching screws.
    WARNING Care should be taken not to damage the radiator cooling fins and tubes during fan removal.
  12. Remove radiator fan by lifting up from the engine compartment.
Radiator fan mounting points
To install:
  1. Install the radiator fan into position on the radiator.
  2. Hand-start all radiator fan fasteners.
  3. Tighten all radiator fan retaining screws to 55 inch lbs. (6 Nm).
  4. Connect the radiator fan electrical connector.
  5. Carefully lower the vehicle.
  6. For turbocharger equipped vehicles: Inspect radiator inlet neck O-ring. Replace if necessary. Install radiator inlet neck. Torque fasteners to 55 inch lbs. (6 Nm).
  7. Connect the upper radiator hose to radiator. Align hose and position clamp so it will not interfere with the engine or the hood.
  8. Install upper radiator closure panel and center brace.
  9. Install grille.
  10. Install battery tray and battery.
  11. Connect cables to battery.
  12. Fill cooling system.
1helpful
How to remove a radiator from a 1988 cadillac seville
1988 Cadillac Seville 4.5L TBI 8cyl Repair Guide
Radiator - REMOVAL & INSTALLATION
On the 8-250 and 8-273 engines use only a coolant solution specifically designed for use in aluminum engines.
  1. Disconnect the battery ground cable.
  2. Drain the cooling system.
  3. Disconnect the air conditioning compressor, if so equipped, and position it out of the way without disconnecting the hoses.
  4. Remove the clamp that holds the air conditioning high pressure vapor line to the cradle.
  5. Loosen the hose clamps and disconnect the upper and lower radiator hoses.
  6. Disconnect the two transmission cooler lines and plug them.
Disconnect the heater return hose, if so equipped.
  1. Remove the two top radiator cradle clamps, straps or sheet metal cover and the fan shroud. Disconnect the reservoir hose from the filler neck.
  2. Remove the vacuum hoses, if so equipped. Mark them for proper installation.
  3. Pull the radiator straight up and out of the car.
  4. Reverse the above procedure for installation.
Fig. 1: Radiator fan shroud mounting - diesel sedans, gasoline-engined cars similar
Fig. 2: Some radiator fan shrouds mount like this
Fig. 3: Common coolant recovery tank, mounted on the inner fender
Fig. 4: Removing the support bolt - radiator removal
Fig. 5: Removing the support - radiator removal
Fig. 6: Removing the radiator metal cover bolt - radiator removal
Fig. 7: Removing the radiator metal cover - radiator removal
Fig. 8: Removing the radiator overflow hose
Fig. 9: Removing the transmission oil cooler lines - radiator removal
Fig. 10: Removing the radiator
Fig. 11: Removing the hose from the radiator fan shroud
Fig. 12: Removing the power steering tank bolts from the radiator fan shroud
Fig. 13: Removing the power steering tank from the radiator fan shroud
Fig. 14: Removing a common radiator fan shroud
I really hope help with this (remember rated and comment this).
7helpful
2answers
How to remove a radiator from a ford taurus
Disconnect battery ground cable. Remove battery. Remove battery tray. Remove clip retaining contant control relay module and position module aside. Remove radiator cap. Raise vehicle front end as high as possible. Remove radiator splash shield. Drain radiator. Remove the radiator mounting bracket assembly. Remove lower radiator hose. Partially lower vehicle. Remove upper radiator hose. Remove radiator overflow hose. Remove upper A/C condenser core retaining bolts. Remove upper transmission oil cooler tube clips. Remove lower transmission oil cooler tube. Raise vehicle. Remove lower transmission oil cooler tube clips. Remove lower transmission oil cooler tube. Remove transmission oil cooler bracket and position transmission oil cooler aside. Remove lower A/C condenser core bolts and position A/C condenser core aside(be careful not to loosen the AC condenser lines. Remove radiator support bracket. Remove radiator out through the bottom of the vehicle.
Installation
Position radiator. Position radiator support bracket and tighten nuts. Position A/C condenser core and tighten lower A/C condenser core bolts. Position transmission oil cooler tube and install transmission oil cooler tube bracket. Install lower transmission oil cooler tube. Install lower transmission oil cooler tube clips. Install lower radiator hose. Install radiator mounting bracket assembly. Tighten bolts. Install radiator splash shield. Lower vehicle. Install upper tranmission oil cooler tube. Install upper transmission oil cooler tube clips. Install upper A/C condenser core retaining bolts. Tighten bolts. Install radiator overflow hose and tighten clamps securely. Install upper radiator hose. Position constant control relay module and clip securely. Install battery tray. Install battery. Connect battery ground cable. Fill and bleed cooling system. Start engine and inspect for leaks.
1helpful
I need 2 know how to remove the radiator
THIS IS a 1995 LINCOLN CONTINENTAL W/4.6L ENGINE
iIBELIEVE TOWN CAR IS DIFFERENT LET ME KNOW IF SO AND PLEASE DONT FORGET TO RATE ME
REMOVAL
  1. Disconnect battery ground cable (14301).
  2. Drain engine coolant.
  3. Remove engine air cleaner (ACL) (9600).
  4. Remove upper radiator hose (8260) from water bypass tube.
  5. Remove radiator overflow hose (8075) from radiator (8005) and fan shroud (8146). NOTE: Loosen transmission oil cooler lines while securely holding radiator connector with a back-up wrench.
  8. Disconnect engine control sensor wiring (12A581) from the auxiliary electric cooling fan motors and the CCRM.
  10. Remove splash shield from lower radiator support (16138) and front sub-frame (5C 145).
  11. Remove lower radiator hose (8286) from radiator. NOTE: Loosen transmission oil cooler lines while securely holding radiator connector with a back-up wrench.
  14. Support fan shroud, radiator and A/C condenser core (19712) with a suitable jackstand. Remove lower radiator support. Position jackstand aside and carefully remove radiator and fan shroud.
  1. Remove two retaining bolts for fan shroud at top of radiator and remove fan shroud from radiator.
  2. Remove upper radiator hose from radiator.
INSTALLATION
  1. Follow removal procedure in reverse order.
  2. Tighten fan shroud bolts and A/C condenser core nuts to radiator to 3-5 Nm (27-44 inch lbs.) .
  3. Tighten lower radiator support bolts to 8-11 Nm (71-97 inch lbs.) .
  4. Tighten transmission oil cooler lines to fittings to 25-28 Nm (18-21 inch lbs.) .
  5. Tighten power steering/transaxle oil cooler and splash shield retaining screws securely.
  6. Refill engine coolant.
2helpful
2answers
How to replace a radiator in a chrysler concorde 1998 3.2
drain radiator.. remove upper and lower radiator hoses ,,remove transmission lines..remove bolts from cover on top of radiator.. lift out radiator.
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
