Question about Cameras
Unable to read my memory stick - Cameras
  • 3 more comments
  • Anonymous Sep 30, 2008
    When I want to see my pictures says there is 102 and there is no pictures.
  • Anonymous Oct 08, 2008
    my memory stick will not read i changed it and it still will not read
  • terrencenr Oct 14, 2008
    I purchased a Memory Stick Duo Adapter with a 2GB Lexar Memory Stick Pro Duo card. However I am unable to copy the pictures off the camera to my laptop. I can see the pictures on the camera but when I connect it to the laptop and view the contents of the memory stick the thumbnail imagesdon't show and I'm unable to copy or move them to my hard disk.
  • holdertom2 Nov 06, 2008
    I have Sony DSC P71 and have the same problem. One of the limitations of the camera is the 128 MB memory stick, so I purchased a 1 GB Sony Memory Stick PRO Duo to increase capacity. When I insert the stick (in the adaptor) I get a C:13:01 error message (memory stick error). Will the camera simply not under any circumstances accept a larger memory stick, or is there a fix for this??
  • slemcmob Dec 26, 2008
    Need a solution bought the camera second hand for my son but I have a 1 GB Sony Memory Stick PRO Duo purchased and it says memory stick error..I have Sony DSC P71 ! I bought the lexar brand but works in other camera? can someone help me slemcmob@hotmail.com
    Champion:
  • 203 Answers
Give me more details-camera model-type of card and size of card-1gb-2gb-etc and I can help you!
Posted on Aug 13, 2008
X205-SLI1 17" Notebook PC PC Notebook 3 beep
Memory problem:
Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | Toshiba Satellite X205-SLI1 Notebook
Unable to read my memory card, it seem to be memory slot problem
i need to open my SanDisk M2 memory card, but my card reader is unable to read it. please help. there are important files on this memory card. thanks in advance..
Oct 19, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
When I power up it runs for 4 seconds and shuts down
Hi There!!
This sounds to me like you have a power supply problem. Anything that you added extra to your system,even a fan or cd drive can cause the system to shut down. You will have to get a more powerfull powersupply.
Hope this will help you.
Jan 12, 2010 | MSI KM4M-L Motherboard
Memory stick properties says full but unable to read files
connect the memory stick and open it then goto tools ...>folder options...>view...>select show hidden files.....> ok
it will show the all files right click on the folder and uncheck hidden options ...
if this one not solve your it will be problem with your memory stick ...you can format it.......
Nov 06, 2009 | Electronics - Others
3 short beeps.
This indicates a memory problem
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Sep 14, 2009 | EliteGroup K7VMM Motherboard
Did not boot and with 3 beep sound
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
Aug 04, 2009 | Computers & Internet
MY PSP IS UNABLE TO READ A MEMORY STICK
Try different known good memory sticks and if they don't read any of them, then the slot is bad and since thats connected to the main board, it would need to be replaced.
Jun 16, 2009 | Sony PlayStation Portable (PSP) Console
PSP is unable to read a memory stick
you should get repair your PSP. Then check if your memory stick work. For sure, the problem is on the PSP.
Mar 29, 2009 | Sony PlayStation Portable (PSP) Console
4G sony mem stick pro duo high speed unable to read by computer
how did you get ur flash player please tell me got the same psp
Jan 09, 2009 | Sony PlayStation Portable (PSP) Console
Loading music to psp
Make sure you copied your music to the ms0:\Music\ folder.
By any chance, can your psp read pictures from the memory stick?
Dec 22, 2007 | Sony PlayStation Portable (PSP) Console
Cameras Logo
184 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
