SOURCE: 2000 Daewoo Laganza no compression
You are more likely right to think you have done some damage to the cylinder head. If you have no compression on number 2 & 3 cylinders then I would take the head off and inspect and recondition the head. You may also have damaged the pistons or rings. Anyway with out looking for any damaged parts, you will not find what parts you will need. I would get a workshop manual for the vehicle to help you. Also if you decide to rebuild the engine, fit a new timing belt.
SOURCE: I have replaced timing belt have checked the
sounds like bent valves or as a worse case scenario you have the CAM shift 180 degrees out. That timing mark will line up in the correct position and when it is 180 degrees out. If the original timing belt broke while the vehicle was running the most likely scenario is the valves were bent when the belt broke. Line everything up with the belt in place now disconnect the belt and turn the cam 180 degrees til the mark lines up again and then put it back together and see what your readings are and if that corrects the problem.
