AKAI CT 3226
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Posted on Jan 15, 2008
  • 152 Answers
SOURCE: Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Posted on Feb 05, 2008
  • 20 Answers
SOURCE: Akai 32" Model #CT3226
Replace the tact switchs, BEFORE thinking processor. They are about $2 a piece available To verify if it is the switch's unsolder them carefully remove them and try the remote to operate set, If it works correctly then that is your problem. If not ,Then suspect eeprom and or processor.
Posted on Feb 21, 2008
  • 20 Answers
Try holding both volume buttons on the t.v. down at the same time.
Posted on Mar 19, 2008
  • 13433 Answers
SOURCE: Toshiba CT-90275 3 digit code for Direct Tv R-16
this might be helpful. Maybe not. But anyways.
Posted on May 22, 2008
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
I have apex dt-250a digital converter box and I lost the remote. Purchased RCA universal remote and I have not a clue what codes I need or how to enter them. Can you help?
I programmed a Radio Shack 5-in-one remote to my Apex DT-250. Select cabel/satelite, hold p until the light blinks twice, then enter the code 0749. It works! If your universal remote uses a three digit code, use 749. If it uses a five digit code, use 00749. I HAVE A PROBLEM THOUGH... I don't know how to scan for channels! It says "please do auto channel search", but how do I do that? Please, if anyone has this answer, let me know. I finally programmed the universal remote, but it's basically useless without being able to do an auto channel search.
Jan 31, 2011 | RCA Televison & Video
I cant figure out which button is for the code search on this remote
It should be channel up button. Just keep pressing it, allowing 3 seconds in between presses. Once your television turns off, you have found the code. Then press enter, and try turning your television back on. (Note: not all televisions will power down. Some may only change the channel)
Nov 04, 2009 | Toshiba CT-877 Remote Control
Programming channels
The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
Sep 15, 2009 | Trinity CT-V710 7 in. Portable TV
Can't get set top box remote to recognize TV
There are usually generic codes listed behind the rest, try those, or there is usually a code search function, try that, otherwise please let us/me know if you are using DirectTv or what kind of set top box.
Hope this helps
Apr 12, 2009 | Televison & Video
Akai CT-2868AT
I had the same problem with a broken remote for the Akai CT-2868AT which meant I could not access the AV channel. I bought the one-for-all (model URC-7711) universal remote which worked with this model TV.
May 12, 2008 | Televison & Video
Jan 15, 2008 | Televison & Video
Remote wont work
Our experience is that most "Universal" remotes do not support the menus used to adjust Akai product. I don't know who the US distributers of Akai are but if the original remote is still available this is usually the best way to access the menus & adjust the set. Some operating instructions may be available as PDF files online & it might be worth searching for them to get the best results.
Jan 08, 2008 | Akai CF2791 27" TV
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
