Question about Sony Cyber-shot DSC-W90 Digital Camera
No screen, no pictures
I think the camera got dropped, in the case however.
Will turn on, lens opens but screen in black and cannot view anything. Will review pics however. Will take photo, but photo is black.
  • 4 more comments
  • thelonestar4 Oct 31, 2008
    when the camera is turned on, the lcd screen is black, hardly visible in direct sunlight. have any solution? i would greatly appreciate for the solution.
  • south_park Nov 02, 2008
    I similar problem, camera turns on and lens opens, and it even focuses and takes pictures....but the LCD screen is blank.Tried the obvious first by checking all of the settings, but to no avail. Help?
  • Anonymous Jan 18, 2009
    no screen, no pics
  • Anonymous Feb 15, 2009
    same problem...
  • arieccc Feb 27, 2009
    i got the same problem, camera is on but lcd is black at all.
  • euribe711 Mar 19, 2009
    I have the same problem. However, mine comes back at times. It is black when is turned on, then i would turn it off and for no particular reason at all, it starts working as if nothing had happened. In fact, I sent it for service to Sony when it first happened and they did not find the problem since it worked when they got it.
    Aggravating to say the least.
Had exacty the same problem (black screen, could not take pictures) I also tried the sollution in http://www.fixya.com/support/t253037-dsc_w90 (tapping on the all cameras sides except one with buttons) and it worked! Thanks man, it was gf's camera and shes happy now :)
Posted on May 30, 2009
Silly or not. Coincidence or not, I tried this solution from another type of problem and it worked. I would try it again if it happens but for now it made it work:
Posted on Mar 19, 2009
I have the same issue. i believe my mom dropped this too and i don't know what to do. i think the lens go messed up cause it's not allowing to view what im wanting to take a picture at. DARNIT!
Posted on Sep 29, 2008
Nikon d3000
did you try a different lens if you did send your camera in for repair . the lens gets damaged easy
Feb 07, 2013 | Nikon D3000 Digital Camera
Fuzzy Pictures w/ Nikon D3000
If this is a new camera, it should still be under warranty. I suggest you contact Nikon before doing anything else to determine if the repair would be covered under warranty. Nikon also would be in a position to advise you as to what the problem might be so that in the event that the repair is not covered under warranty, you don't replace the wrong thing.
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
I have the same problem as this person: I have a Canon Digital IXUS 500 with the same problem: when turned on previous pictures can be viewed menu and fuctions available , unable to take and view pictures...
Hi!
There could be two causes - a dead CCD or a broken shutter cable inside the lens (so the camera is not able to open the shutter) - they both are common problems with the camera and are expensive to repair. I don't think it's worth it.
Sorry for the bad news!
Tom
Oct 09, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Camera powers up fine. Black screen when looking
some cameras have different languages
find the one that related to view images and the camea must be on and othe funtions are automatically diabled at that moment in time.
Jul 31, 2009 | Canon PowerShot A630 Digital Camera
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 12, 2009 | Cameras
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Sony Cyber-shot  DSC-W90 Digital Camera Logo
233 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
