SOURCE: headphones quit working.
I'm guessing no because RCA doesn't even sell this product anymore. Btw, I don't have a wire on my headset and it's the same model.
SOURCE: Wiring code for the jack?
You're right on the code, with the exception of the right and left. I'm an AKG dealer and spoke to their service department. Here goes:
White=Ground
Yellow=Left
Red=Right
To confirm this, I used a multimeter in continuity mode and tested them. This code is 100% correct.
SOURCE: loose/broken wire
the best way to check if the head speaker is ok, is by opening up the headphone bit and disconnect the wires and make a new connection with a naked end , and test it in a stereo, if that still works the you wont have to buy new headphones you can just disconnect all the wires and buy or make you own connection again. let me know if you help making a new connection. cheers
SOURCE: K27 Headphones stopped working one
See my tip on replacing dodgy plugs/cables on heaphones. You will find it by clicking my name. It's worth trying to replace the plug just in case.
