Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore bottom freezer keep freezing up.
Freezer coils keep freezing up and I have to thaw them ever few weeks.
  • Anonymous Aug 13, 2008
    My Kenmore bottom freezer is 21" model purchased in 1999. Recently the freezer started freezing up inside and leaking water on the floor. Have cleaned the front of the coils behind the toe grid with brush and vacuum. Still frozen up and leaking. Shall I defrost it and start again??
  • Papajoe44 Aug 29, 2008
    My kenmore bottom freezer has frosted up. It was recently purchased used. I am searching for troubleshooting recommendations to try. I haven't done anything yet.
  • 4 Answers
Just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Posted on Aug 15, 2008
Kenmore side by side drain tube in freezer keeps freezing up Any solitons other than to keep thawing out the the every two weeks
try to locate the drain tube on the bottom and blow it with compressed air to clear the way for the condense water to drain out or open the freezer back panel and run hot water to see if it clears.
Dec 11, 2013 | Refrigerators
Refrigerator won't defrost.
Replace the defrost thermostat and defrost heater in the freezer.
Aug 19, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
GE TCS18PADBLBS Freezer
if the drain line is frozen or clogged then you have to remove the back freezer panel and with a hair dryer at the bttom of the evaperator coil thaw the ice that is built up in the evaperator pan ouce you have it thawed you can pour water into the evaperator pan and it will run into the drainpan if you pour water into the pan and it does not run into the pan keep thawing
Apr 24, 2008 | Refrigerators
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Aug 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
426 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
