Question about Xerox Office Equipment & Supplies
I have a xerox Docucolor 621 which has a Close Door Error, The Tech Who has looked at it says it needs a new main board and a Sensor PCB costing $2,880. Is there some other way to fix this?
    President:
  • 2,072 Answers
You can try looking for a local service provider other than Xerox.
Go on the Xerox.com website and look under dealers and see if their dealer locater has location listed in your area.
You can google a business called " the parts drop" and see if they have that part for cheaper.
I don't know why you would have to replace both parts though. And honestly, xerox is excessivly expensived on service. Horribly expensive.
Posted on Aug 13, 2008
Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Nov 19, 2010 | Xerox DocuColor 3535 Copier
When i print one document on my xerox docu color 4lp on the printer display's this message "U6-4 Cycle power"
U6-4 sounds like an NVRAM error and could be a bad board.
I think they probably be the Main System Controller Board 160K58571 or the Engine Controller/MCU 160K60530
Whit
Item, Inc.
Aug 10, 2010 | Xerox DocuColor 4LP Laser Printer
Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Jul 19, 2009 | Xerox Office Equipment & Supplies
Xerox docucolor 250 error code 042-326
Belt Failure turn the mach. off and un plug for 20 to 30 seconds then turn back on if this dosent sole you need to call a tech to replace the main belt
Jun 18, 2008 | Office Equipment & Supplies
Have error 010-349
That is the front thermistor on the fuser has gone bad.Most likely need to replace the fuser module.
The part number is 008R12904.
You can look in the fuser and see if there is something stuck under the front thermistor.
But be careful that fuser is extremely HOT.
May 20, 2008 | Xerox DocuColor 3535 Copier
Xerox Docucolor 2006 Error Code 009-358
Solution Listing for Symptom The Printer's Control Panel Displays 009-358 - Contact Service Solution (try these steps in order) 1. Turn the printer off, wait 30 seconds and turn the power back on 2. The printer will need to be repaired power off the printer and contact service Not good news I am sorry to say. http://office.support.xerox.com/srvs/cgi-bin/webcgi.cgi?new,ques=User_Type:4,templateset=xo_legacy,kb=out98pkb,ques=obj(69892)::obj(707),ques=obj(34668)::obj(67237),Company={5AC8CA72-62D5-4658-8D6F-D2F393C98A63},varset=prod:2006 http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-2006/sprt-enus.html Good luck, Tim
Mar 15, 2007 | Xerox DocuColor 2006DPC Laser Printer
124 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
