Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mr Slim Issue
I have a AC heat unit in my bedroom. Just yesterday it stopped working. I changed remote batteries, checked the breaker and fuse and no problem. I hit emergencu button under cowling and nothing. Anything else to check? I'd appreciate any help
S
Need to know the year of the system, I would reccomend going to www.mrslim.com and looking up your unit. You will be able to get the full service manual for it
Posted on Aug 26, 2008
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Remote is inaccurate
did you change the batteries ?
Dec 07, 2013 | Mitsubishi Heating & Cooling
Had a thunderstorm here this morning, I'm sure it was a lightning strike as our TV's do not work either. On our Mr. Slim unit the green light flashes continuously on the inside unit but the...
It could have takenout the compressor but I would start with the breakers or fuses , then move to the capisitor. But first just shut it down for a bit at the breaker and then reset the breaker.. Hope this helps let me know jon
Aug 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I installed a 2 ton Mr.Slim today. On the remote I could not find the sun icon for heat. I seen all the rest icons. So I couldn't try it on heat. It did work on a/c. And every thing else seemed to work OK....
No by mistake, cool only remote has been packed with you set.Or remote icon problem. Please contact your supplier to replace heat and cool remote. Thanks.
Jan 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a Mitsubishi Mr Slim air conditioning unit, i've checked the circuit breaker, the remote works but the unit will not engage.
DOES IT DO ANYTHING I THINK ON THE RIGHT SIDE IF YOU HAVE YOU BOOK IT FLASHES ERROR CODES IF YOU HAVE THE COVER OFF
Sep 18, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
Aug 26, 2010 | Mitsubishi Heating & Cooling
No heat generated from the inside unit in Misubishi Mr. Slim
If you do not have a windbaffle installed on the outside unit the unit may never come out of defrost in low ambient temperatures. Depending on the outside temperature it might be telling the pcb to stay in defrost to keep the compressor from slugging and being damaged.
Jan 20, 2010 | Heating & Cooling
Mr slim unit in bedroom 9kbtu - room 11x12'- is humid, awful
Lets clarify. DRY mode only dehumidifes that air and does not cool. Cool is used for cooling. Dry mode doesn't normally have temp control; it is automatically set by the unit. I think 9000btu is a big unit for the room; it is overkill. I would switch to a 5000btu unit. it cannot be fixed and the BR unit needs to be uninstalled and the new unit needs to be re-installed. The price of commisioning, de-commisioning and new unit is something in which you will have to pay.
I take the time to answer your questions, so please rate me.
Thankyou
Mat
Aug 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Unit does not work
all the mitsubishies had auto diagnosis,you must set up with the remote control to see the code and how many times blinking the button to the indoor unit.
Oct 09, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
212 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
