Question about Linksys Wireless-G WRT54GS Router (e125894)
Can't access my encryption key anymore
Recently i noticed i can't connect wirelessly to my router anymore. It says my passkey isn't correct. So when i try to get my manual encryption key through Linksys Easylink Advisor, it doesn't show it anymore. Every section except the password i entered says N/A. and that password doesn't work. I try to change my wireless security through Easylink, but it says my router's not supported!
I'm suspicious of a whole bunch of routers around my neighborhood. i found 3 new ones from my laptop and think maybe someone hacked my settings. any advice? Or at least someone tell me how to completely reset my routers settings.?
  • 2 more comments
  • Jake Raquel Aug 13, 2008
    ok. the clarify:
    I'm using it currently on a wired connection. (wired = working).
    Tried the linksys config using the default gateway (192.168.1.1) doesn't work at all. says "Failed to Connect".
    Tried ipconfig/all and made sure 192.168.1.1 WAS my gateway.
    NOW for some reason, i can't even get to the "router password" screen from my laptop. says "may be due to timeout or user action".
    I will try to completely reset my router with the 10-second press. But i didn't see an option for WPA security when i first set it up. i know there's vulnerabilities with WEP, because there's tons of tutorials online. Is there a different configuration software than the included Easylink Advisor that works better?
    here's a few images.
    More problems: Even after a complete reset, I still can't get to the default linksys admin page. i'm able to ping it, but it never opens. LELA still doesn't recognize my router as a compatible device. The firmware is apparently rolled-back to 7.50.2, so i don't see why there's still a problem. I'd really like some more help on this. I don't want my connection wide open for everyone to steal. (I seem to get connection THROUGHOUT MY WHOLE NEIGHBORHOOD.)
  • Scott Griswold May 11, 2010
    Are you unable to access the router config or just unable to get connected to the router via wireless?
    You should start by directly cabling to the router rather than trying to config via wireless. If you are able to access the router config this way with its IP address, then you should be able to get access to your wireless key. Are you using WPA or WEP? If as you say you have other users in the area, and you were suing WEP, it is possible that your were hacked since WEP is easily hackable. Switch to WPA and use a password at least 10 or 12 characters in length. Give your router a unique name and then hide the SSID. This will keep anyone from easily seeing your router and being nosey.
    If you are unable to gain access with the router connected via hard wire, then your router admin password has been changed. You can reset to factory defaults by pressing and holding the reset button on the back of the router for 30 seconds. You should then be able to access the router via the default IP, username and password.
    IP: 192.168.1.1
    Username: blank
    Password: admin
Ive got kinda similar problem, bought myself a laptop but cannot get wireless internet on it, assomeone has changed password ansd username on router when setting it up for the previous laptop. now nobody knows what are the passwords etc. i was wondering if i reset my router to set it up all over again, put my own ip in it, would than mean that i have to do exactly the same with th other laptop? i just dont know computers that much and i dont want to mess up my mates laptop/ could you pls help? thank u u can reply to my email pls
paulinabuda at g mail dot com
Posted on Sep 26, 2008
  • Linksys Master
  • 6,487 Answers
You can try accessing the router setup page or the user interface of it byu typing the http://192.168.1.1 on the address bar of the computer that is wired to the router and working to the internet, of you can also call linksys tech support so you don't need to reset the router because they can tell you how to change and check all the settings on your router this is the number 800-3267114, but if you want to reset the router just press and hold the reset button of it for 10 seconds,,,,
Hope that helps.......
Posted on Aug 13, 2008
  • Mark Gil
    Mark Gil Aug 13, 2008
    Yes, reset it then if you want to enable WPA update the firmware for you to have the security option..
Need passkey for a motorola H700. it says it can connect to my pantech jest 2 and i need the passkey
Network Key (WEP, WPA, WPA2 Encryption key) To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 05, 2012 | Motorola Mobility H700 Wireless Headset
Router wifi and computer dont connect
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Feb 25, 2012 | NetGear Computers & Internet
My son has been trying to log in on his ps3 with a headset but it says he needs a pass key?can you help plz.
Theencryption key secures your data from unauthorized access. The router's password is a Passkey or Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the PS3, laptops and desktop computers cancommunicate with your wireless router.
Apr 13, 2011 | Audio Players & Recorders
Do not know passkey. Where can I find passkey?
The network security key (passkey) is the router's wireless encryptionkey.
To connect to your wireless router, it needs the router's wireless settingsconfigured ie SSID, WPA or WPA2 encryption key and also the wireless cards inall the laptops and or computers needs to be configured with these router'swireless settings. Then the laptops and desktop computers can communicate withyour wireless router.
Feb 20, 2011 | Samsung Computers & Internet
Whats a wpa key? I have tried connecting to my router on my wireless device and my wireless device ask's for a wpa key? is it the same as a lan key?
WPA <<===>> WIRELESS PROTECTED ACCESS
You need to use an Ethernet cable to connect a computer to the router, and then access the web-server inside the router, and then run the "Wireless Networking Setup Wizard". When you do, you will set:
* the SSID ("network name") -- pick anything you prefer
* the encryption-level (hint: use 'WPA')
* the password for the network -- pick anything you can remember
Then, from a wireless device, do a "View Available Wireless Networks".
Select the SSID, and enter the password, to make a connection.
Feb 01, 2011 | D-Link DIR-615 Wireless Router
Cannont connect wireless router to computer
The wireless authentication key is your wireless router's encryption key. You need to configure the wireless card in your computer with this encryption key. You cannot access the wireless router unless this encryption is correct.
For details on wireless encryption and -
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 30, 2011 | Computers & Internet
When i try to connect my sons laptop i am prompted for the security key . i then recieve this message. wireless authentication failed because of a timeout
First of all make sure you are typing the correct security keys. If you are then just disconnect the power from the router for 15 seconds and plug it back in. This should work.
Hope this helped.
Jan 29, 2011 | Belkin Computers & Internet
I own a belkin n150 router. i've used ti on my laptop and now i bought a another computer and it won't let me access my router. it is asking for a security key. any idea how to access it or find it?
Your wireless card in her laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (security key) is in your wireless router, without this key the wireless router won't allow the laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 29, 2010 | Belkin N150 Enhanced Wireless Router...
Is using a wireless connection (U.S. robotics) was connecting automatically for along time. Suddenly they ask for the network passkey when entered there is a mismatch now i cannot login from the wireless...
I would suggest you to change the wireless user name and the network key. This should solve the issue. For more information click the link below and read the instruction carefully and follow the steps.
http://www.thinkbroadband.com/hardware/reviews/38-usr-9106.html
Dec 28, 2010 | Computers & Internet
Cannot connect 2 computers to Motorola SBG900 wireless cablemodem
mac and pc security keys are not interchangable. I suggest not using a a key for both units. You can reset the router by unplugging it for 1 minute. or you gain access to the router through the web address. 192.168.1.1 Type this into the address bar to gain access to the router.
Jul 10, 2009 | Arris SURFboard SBG900 802.11g/b...
Linksys Wireless-G WRT54GS Router (e125894) Logo
830 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
