Question about Zhone (6218-I2-200) Router
Great problem with router zhone 6218
I cannot enter to the router configuration
can you say me why?
i need to change info to open the wifi
please help me
    Novelist:
  • 143 Answers
I assume that you're not prompted with the log in screen. if so, you need to check if your computer is properly connected to the LAN/ethernet port of the router (Note: you need to use a hardwired computer if you want a stable connection while checking your wireless settings) and if it has a valid ip address which shoud be within the subnet of the router's ip address (Note: by default the router's ip address is 192.168.1.1 and "admin" is the default username and password)
if you're not sure of the current ip address of the router. go to command prompt and type ipconfig. it'll list there the default gateway which is the router's ip address.
now if you have checked that the computer has a valid ip address and it is properly connected to the router but you can't still access the router's page, there could be a program that is blocking the connection. try to disable any firewall or any antivirus programs installed on your computer.
hope this'll help you. you can click here for the manual if you would like to read some more about the router.
ciao!
Posted on Aug 13, 2008
I have a Zhone router, model number 6218-I4-200-0CL. I'm trying to figure out how to forward a port, but there is no actual "Port Forward" option under the configuration options. There is...
Hi!
Please follow the guide here... It's for a different Zhone model - but it should work exactly the same!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Mar 17, 2011 | Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM...
How to configure router zhone 3400
Here is the user manual for your router: www.psitec.com/manuals/etherxtend/ethx3400-11501000UG.pdf
It should help you set up and configure your router. Good luck!
Feb 28, 2011 | Zhone (6218-I2-200) Router
I NEED TO RESET MY WIRELESS PASSWORD, ZHONE MODEL 6218-12-200-0CL PL SEND INSTRUCTION
YOU CAN RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
Here is the link to official Zhone support site for further detail (if required)
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Dec 03, 2010 | Zhone (6218-I2-200) Router
ZHONE 6218 unable to connect
Try to configure you router with WPA authendication. provide some encryption password,if asked. Then configure your lifebook with manual ip by wifi adapter ->network settings-> tcp/ip properties - > specify manual IP something like 192.168.1.2 Now try connecting to your router.It should ask for network key and will connect if key provided matches with the one configured.
May 21, 2009 | Zhone (6218-I2-200) Router
When using utorrent or any other torrent client it says i have problem with my network configuration
You'll need to forward the port you have selected in your BT client (you can set it / checj ut in uTorrent: Ctrl+P -> Connection -> Port used for incoming connections. It should be something between 40000-52000.) to accept incoming connections.
Unfortunatly there is no guide for your router model, but you can help with this one http://www.portforward.com/english/routers/port_forwarding/Zhone/6218-12-200-0TT/6218-12-200-0TTindex.htm, also port forwarding is referenced in your owners manual, so you should check that too.
Mar 21, 2009 | Zhone (6218-I2-200) Router
How to turn zhone 6218-i2 router to wireless, now am using cable?
hi Jeffkrick.
if you go to the link you can read the manual.
when you open this link you will see the pages at the top of the page just click on the pages and it will let you read it.
Zhone 6218 I2 User Manual
Nov 21, 2017 | Zhone (6218-I2-200) Router
Zhone 6218
To restore the router to factory default settings, select Management ->
Settings -> Restore Default.
I take it that is what you have tryed?
http://zhone.com/support/downloads/cpe/
try finding the correct firmware to install
Aug 12, 2008 | Zhone (6218-I2-200) Router
Where can i log on to the router or change its password?
To access the router's configuration you need to type its IP address into a web browser. The default IP is 192.168.1.1 but if that doesn't work you can find it out with the following steps:
  1. Go to Start->Run
  2. Type "cmd" without the quotes into the box and press Enter
  3. type "ipconfig" without the quotes into the larger black box and press enter
  4. The number across from the "Default Gateway" is your router's IP address
I hope this helps!
Jun 13, 2008 | Zhone (6218-I2-200) Router
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
Zhone (6218-I2-200) Router Logo
827 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
