Question about Smith Corona Wordsmith 200 Typewriter
Grinding and locking typewriter
When I try to make a correction, the typerwriter makes a grinding noise and then locks, do you know why and do you have any solutions to fixing it?
    Scholar:
  • 183 Answers
Sounds like the corr.tape lift mechinism is jammed, or problem with transport motor or power supply. but if it backspaces ok it is probably the lift mech. needs a repair shop
Posted on Nov 29, 2008
Nissan micra central locking locks but makes a grinding sound on on side of the car.
Put your ear to the door and listen to where the grinding/buzzing noise is coming from when you lock the door, sometimes it maybe more than one door! The door it's coming from need a door actuator, common fault with the k12 micra's, which i'm guessing this is a k12 model!
Feb 04, 2015 | Nissan Cars & Trucks
1998 Chev.S10 brakes making a grinding, roaring noise
THIS SOUNDS TO ME LIKE YOU HAVE BEARINGS THAT ARE BAD. WHEN IT ACTS LIKES BRAKES ARE APPLY ON THERE OWN AND GRINDING,THAT IS THE BEARING LOCKING UP.HAVE CHECKED ASAP
Dec 23, 2014 | 1998 Chevrolet S-10 Pickup
Why does the steering wheel locks when I try to make a left or right turn in my 2002 Lincoln LS? What is wrong when I hear a grinding noise coming from the engine when I try to make a turn?
the grinding noise is from the steering pump going into overload and the pressure relief valve is working. If you have recently worked on the pump or steering check that the hydraulic lines have correctly installed It appears that when turning right the steering is trying to turn left.
Aug 30, 2014 | 2002 Lincoln LS
4x4 hubs make grinding/clicking
Check the cv joints as they make that sort of noise when they are worn out.
Mar 03, 2013 | 1985 Ford Bronco
Full lock grinding noise micra
A "CLICKING" NOISE WHEN TURNING USUALLY INDICATES A BAD CV JOINT. LOOK AT SIDE MAKING NOISE AT INNER AND OUTER CV RUBBER BOOTS...IF CRACKED OR TORN....PROBABLY NEED NEW CV JOINT
Jul 30, 2012 | Cars & Trucks
1998 dodge grand caravan. The doors lock automatically when you begin to drive. They make a loud grinding noise when this happens. The locks still work but it make the sound when you lock or unlock the...
That sound is going to be your door lock motors wearing out. I would suggest getting them replaced pretty quickly as they will soon stop locking altogether. It's not cheap, but it isn't horribly expensive either.
Mar 05, 2011 | 1998 Dodge Caravan
Swintec 8016 Typewriter making grinding noise all functions froze
Try some WD40 on the silver shafts that the carrier slides on they do get very gummy.
DickyO
Apr 26, 2010 | Swintec Office Equipment & Supplies
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
CARRIER WON'T RETURN BACK TO THE CENTER
make it sure the cover of typewriter was lock ,self lock no movement of cover means good operation of typewriter.
Dec 20, 2007 | Brother GX-6750 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
