Question about Kirby Generation 3 Bagged Upright Vacuum
Need to replace front vacume propeller
I have the vacume propeller thats in the front part of the vacume, that i need to replace how do you get that prop off the shaft.do i need to tear into the entire vacume or does it come off from the front
    Novelist:
  • 97 Answers
You will have to take most of the vacuum apart to replace your fan.
First; remove the handle assembly by pressing the button on the front of it near the base. Remove the bag unit by twisting the rear of the emptor away from the body, and remove the front nozzle assembly by rotating the belt removal part to the "off" position and flipping the latch at the top of the nozzle.
There's a screw on the very back above the self propel select, and one on the top of the plastic where the cord attaches, removal of these will let you remove the rear plastic piece. Then there will be two more screws above the main power switch, and two on the front of the housing under the headlight. Remove the power cord, and then you can lift the rear housing from the main body.
Now you can remove the screws from the front of the fan housing; I believe there are five. Make sure you keep track which screws came from which position, because they are all different sizes.
To remove the front of the fan housing, put a flat-head screwdriver in the gap at the top to the side of the headlight assembly and pry it apart.
To get the motor pulley off you'll want to grip the pulley with a pair of vice grips, and use a wrench to hold on to the motor shaft in the rear of the machine. Look at the shaft that runs to the rear from the armature, and you should be able to locate a flat section which will allow you to grip it with a wrench... I do not recall the exact size, but there is a standard one that fits it perfectly. The pulley can then be removed. Note that it is reverse-threaded. Keep in mind that you will need to replace all the little plastic washers and rubber gaskets and things that are on the shaft with the fan. They are usually included with the Kirby fan kit, but if not make sure you find some before attempting the repair.
Before reassembly, you'll want to apply a thin layer of adhesive around the edge of the fan housing, making sure you don't glue the safety switch on the front into place.
Reassembly is the reverse of disassembly.
Good luck.
-R
Posted on Aug 13, 2008
  • 357 Answers
Please see this link to get the part and repair instructions...
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Marci
Posted on Aug 28, 2008
Hoover self propell cable needs replacement
Hi there! We recommend taking the cleaner to a Hoover authorized service center to have the self propelled cable repaired or replaced. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jun 24, 2014 | Hoover Vacuums
The vacume turns off when it is put up strat. But works when it is tilted how do i fix it?
I have had this problem and it is in the actual propelling switch which is a real pain to get to and once there, clean and reassemble
Nov 29, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Dec 30, 2009 | Dirt Devil Vacuums
Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Nov 28, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Self propel feature is not functioning. have to push the vacum cleaner
Remove the bottom plate and look for broken or loose drive belt to the wheels. Check the wheels for being bound-up with thread, hair and other debris. Make sure that the motor for self-propel runs when turned on.
Aug 15, 2009 | Vacuums
No suction
Flip the machine upside down and remove the four screws from the baseplate. Replacement should be fairly self-explanatory from there. If it's a self-propel model, note that the v-belt in the front WILL look loose normally, so it does not usually require replacement.
If you have a self propelled model, the belt you need ends in 035, if it's non self propelled it ends in 033.
Contact me if you need more assistance in changing the belt.
-R
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Need illistrated instructions on replacing belts on my self propelled hoover supreme
The flat belt probably has come off, may need to replace it if it hasn't been replaced in a while. May look ok, but am sure it has stretched.
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propelled wind tunnel vacum will notpropell itself
Must be a Hoover, The flat belt may look ok but I am sure it has stretched to the point where under load it won't drive the wheels or the brush roll. Could also be a bad brush roll.
Nov 06, 2007 | Vacuums
Kirby Generation 3 Bagged Upright Vacuum Logo
133 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
