Question about Magellan MAESTRO 3100 98083401 GPS Device
My GPS Maestro 3100 is frozen
What can I do when my GPS frozen?
Please help me.
Thank you
Hold the power button down and hold it about 10 seconds and it should re-boot it. It happens to my husband all the time.
Posted on Aug 13, 2008
Magellan maestro 3100 stuck at bootup screen
did that just happen all of a sudden or did you try and update the 3100 and it failed to boot after that...if you didnt try to update it...turn the 3100 on then use a paper clip to depress the reset on the left side bottom of the gps and let it restart.
if that fails, let me know and ill help you further
bill
Jul 15, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Screen is frozen
if it just froze and you didnt do aqnything to it, like try and install the 2.18 update, try the reset.
turn the gps on the use a paper clip and insert it in the tiny hole on the lower left side of the gps and let it restart..if it still freezes, let me know and ill tell you what you can do next to get your 3100 running again.
bill
May 15, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Maestro 3100 touchscreen calibration off
try this update remember you need windows XP or it will crash or buy the CD for vista and windows 7 http://www.magellangps.com/support/notes.asp?supportID=537
Dec 10, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
Aug 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Maesto 3100 touch screen does not work!
There is an online tutorial that shows you how to replace GPS batteries, parts are many times available though www.ebay.com. The repair manual is at : GPS Repair
Apr 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Need instruction guide
hi!get it here:
http://www.retrevo.com/support/Magellan-3100-GPS-manual/id/2946ag211/t/2/
u might have to make a free registration..if its not working then please look from the retrevo.com website
regards!
Nov 10, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 failed update
go to Tech support at www.magellamgps.com tell them what has transpired and ask for 2.18 Update Recovery Files. This fixed my problem. Took a few email exchanges but I thought the responses were very quick.
Oct 04, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS
Online at Magellan website you can update your magellan maestro 3100
Mar 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
148 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
