Toshiba Satellite M35X-S149  PC Notebook
Problem for Toshiba Satellite M35X-S149 (PSA72U00T00U) PC Notebook
Unstable after RAM increased to 1.21 GB from .5 GB
By aptatl on Aug 13, 2008
Windows XP Home Edition, Version 2002, Service Pack 3.
Has settled down somewhat but won't restart when asked to.
Solution #1
posted on Aug 13, 2008
Not Rated)
bhiga
Rank: Guru
Rating: 86%, 93 votes
If you have another PC, use ImgBurn or another program to burn a bootable CD (ISO) or bootable floppy (if your laptop has a floppy drive) of MemTest86+
If you don't have another PC to burn the image with, remove the newly-added RAM to get your laptop back to a stable state and create the CD or floppy disk.
(Reinstall your added RAM if you removed it earlier)
Boot your laptop with the MemTest86+ CD. Make sure the "Passes" goes to at least 2. If any errors are found they will be listed. If errors *are* found, then either your new RAM is not 100% compatible with your system, it is defective, or it is not compatible with the RAM already on your system (if your laptop has more than one slot for RAM).
Change the RAM configuration (replace the RAM, remove old RAM if your laptop has more than one RAM upgrade slot) and repeate the MemTest86+ test until you get through at least 2 passes without any errors.
Despite what people (even manufacturers) say, not all memory is created equally, and faster memory modules don't always work in place of slower ones. Likewise, you can have two memory modules that work perfectly fine in a system when they are alone, but don't work together in the same system.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite M35X-S149
Questions and Unsolved Problems for Toshiba Satellite M35X-S149
Do you recommend Toshiba Satellite M35X-S149 (PSA72U00T00U) PC Notebook?
Answer
Answer
I have a Toshiba Satellite L25-S119. I just installed Windows 7 and I cant get the audio driver to... (More)
Answer
cannot remove hard drive from my gateway p6301 removed all screws from cover these screws also hold... (More)
Answer
I had a bluetooth adapter on my Acer Aspire 5535 Notebook But I have upgraded to Windows Vista Home... (More)
Answer
intel dx48bt2 basic wiering with cm strorm sniper case & coorsair 750 fans on sniper caseing... (More)
Answer
Toshiba Satellite M35X-S149 Turn on PS, power light lights up, fan comes on and hard drive motor is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
