Question about Dishwashers
How can I turn off the alarm that sounds when the cycle is done on the Miele Optima series dishwasher?
  • Anonymous May 25, 2009
    Help!
  • 4348 Answers
SOURCE: How do I tighten the door on my Miele Optima
there are springs on each side of the door, near the pivot point. Adjust them.
Posted on Nov 01, 2009
  • 177 Answers
SOURCE: I have an Miele Optima Series HG03 dishwasher. The
hi,
try checking the spigot under the sink as quite often the hole has not been opened up enough and there is a shoulder for food to jam up against causing a blockage. Remove the drain hose and have a look in the hole of the u bend.
If ok remove the filter in the base of the unit and remove the non return valve and make sure the drain pump can turn and there is not anything blocking it.
Posted on Jan 20, 2010
  • 457 Answers
SOURCE: Miele Inspira Series Model G2140 U
in this case you just have to know when you can doit or let the professional handle it. but before they come call the company and tell them that your machine has to be reset and to tell you what to press and hold to reset maybe that might work,sometimes you get a acknowledgeable person who knows a litte something something. it could save you some money on the repair.let meknow if i was of some help with a 4 thumbs up post
Posted on Feb 27, 2010
  • 177 Answers
SOURCE: 2 year old miele dishwasher runs without being turned on.
hi,
A F70 fault is the float switch in the base of the unit which is activated due to water in the base. you may have used too much detergent or the wrong detergent causing the unit to over sud or you have a genuine water leak. the continous running noise is the drain pump trying to remove any water.
you need to remove the bottom panel, turn the power off and dry up the water with a towel. then run it again and see if you can see a leak.
hope this helps
Posted on Jun 06, 2010
  • 30 Answers
SOURCE: Miele Optima dishwasher. Doesn't drain,
check the drain solenoid valve if working properly or check if voltage is present if you press the drain switch.
Posted on Aug 12, 2010
Optima G2430 Miele dishwasher with F13 error
F13 Indicates that you have a water intake fault. The machine is not receiving the the proper amount of water quantity. You could turn off the water supply and disconnect the water inlet hose. There is a filter inside, to remove the filter you have to take out the seal and then you could use a pair of needle nose pliers to take out the filter basket. If the filter is clean you and your water supply is good, you have a problem with your flow meter not registering pulses when the water is taken in.
Feb 05, 2012 | Miele 24 in. Incognito G843SCVi Built-In...
I have an optima series miele dishwasher built inn It is not running The alarm goes on and the intake/drainer light goes on please help SOS
Hello, ruizke
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Sep 08, 2011 | Miele 24 in. G2180Vi Built-in Dishwasher
Not drying at end of cleaning cycle
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 18, 2011 | Miele Optima G2470SCVi Built-in Dishwasher
Can I stop the buzzer at the end of the cycle? woken up at 1 am when I put the dishwasher on at bedtime. What a crazy design.
There are three ways.
1. Check the user guide and see whether they have any information,
regarding switching OFF the buzzer.
2. If the buzzer has a open grill from where the sound originates,
paste a plaster over it. or adhesive tape.
3. If you can access the buzzer location. disconnect wire if the
terminals are used or cut it and insulate the ends with a tape. (Try
this after totally switching OFF the main power supply as safety
precaution!
Oct 04, 2010 | Miele Optima G2470SCVi Built-in Dishwasher
My miele dishwasher MOdel G2470SCVI is not draining.
I went on line and looked up the use and mcare and maintanence info.
Feb 05, 2010 | Miele Optima G2470SCVi Built-in Dishwasher
I have an Miele Optima Series HG03 dishwasher. The dishwasher stops after a minute and the intkae/drain error flashes. I tried everything in the manaual but there is nothing blocking the drain or intake...
hi,
Dec 28, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
My Miele dishwasher does not get the plastic refridgerator items dry
Hello Zipmap0202,
I have never found that plastic dries very well in my Miele dishwasher as well.
Check your rinse aid indicator to see if it is on. Next to the soap door there is a door you can add rinse aid to. There is also a dispensing control knob that allows you to turn the amount of rinse aid dispensed up or down. Try changing the setting and see how that works. I have done this and it has not worked well for me. I find opening the door after the cycle is done (Just cracking) it will dry plastic alot better
Sep 16, 2009 | Miele Optima G2430SCi Stainless Steel...
Miele dishwasher Advanta Series. Once the cycle is done the beeper continues to beep until someone opens the dishwasher and the beep then stops. Is this programmable?
the washer starts runs for 10 mins then beeps and beeps all the lights turns on in the programing panel inside HELP
Jun 22, 2008 | Dishwashers
Dishwashers Logo
160 people viewed this question
Top Dishwashers Experts
