Question about Dell Inspiron 8000 Notebook
S-video I am trying to hook the laptop to my tv with a s-video cable. How do I get what is on the monitor to show up on the tv screen?
    Genius:
  • 2,028 Answers
Most tv's aren't compatible, if it has a vga port then it should be, and on some, you need drivers in order for the tv to be used as a monitor. Keep in mind that tv's aren't designed to be computer monitors, and if compatible, often don't get the resolution desired or expected. This is especially true with models that are compatible that use the s-vid cable for the connection. So, if the tv doesn't work simply by plugging it in with the s-vid cable, then look for drivers for the tv at the manufacturer's web site. If none are available, then the tv is not compatible as a monitor. While at the manufacturer's site, you might also check the compatibility.
Posted on Aug 13, 2008
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
Have pavilion xh635 with win xp. tried to hook up video to tv. In video properties selected enable monitor 2. laptop screen went blank and tv in vga mode showed empty desk top backround. Cant get laptop...
Take a look at the checkpoints under the resolution bar. In order to come to your laptops main monitor you have to select "screen 1" and check the main screen check mark. In case you want to use the tv screen as an expansion monitor you have to choose "screen 2" and check the "Extend to this monitor" checkpoint.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 03, 2011 | HP Computers & Internet
I'm trying to figure out how to make the display show on a larger flat screen monitor. Any help would be appreciated. I found where you would change the resolution under Control Panel and it showed 2...
if you are trying to use a lap top to display on a Flat Screen TV, then hook the laptop to the TV with a 15 pin D cable or a HDMI cable(what ever connector you have in common), the switch the TV to PC and then look on your laptop for an ICON that shows a TV set and acomputer screen together. On mine it is hold down the function key and tap the F6 key( Fn+F6) on some computers it is the Fn+F5 key, this switches the display from the laptop out to the TV on to the Aux PC input.
Jan 22, 2011 | Computers & Internet
How can i make the laptop screen show through my tv
Hello.
Simply hooking up is not enough. What type of cable are you using? HDMI? analog VGA? DVI? S-Video?
* You should also use [Fn] button in combination with [F5], [F8] or another button that shows monitor sign as well (CRT/LCD if it's in written form). Possibly by pressing several times in order to achieve results.
* In some graphical cards (usually in Intel Extreme Graphics) you should locate icon on systray (near the clock) and right click on it, then choose (Graphic Options) -> Ouput to -> Intel (R) Dual Display Clone -> Monitor + Notebook (if you are using VGA cable)
A solution in graphical details can be found here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-58625.html#ie
Sep 16, 2009 | Dell Computers & Internet
Connecting and recording camera with s video output on 1221 tx
The cam setup you're trying in your surgery is similar to the type I often setup in Dental operatories for there intra-oral cameras.
You need an tuner, if your external has S-Video port, you can simply plug into it and use windows media center or the cards software(if it came seperate) to record from the s-video feed.
Then you can hook the S-Video output from the laptop to the TV monitor in question and run the laptop in mirrored mode to show the same image on both screens.
Hope this helps,
Chris
May 26, 2009 | HP Pavilion dv6000z Notebook
Screensaver shows on monitor but no Icons...
also press Fn key along with the key that has marked monitor on your laptop keyboard
Oct 19, 2008 | Compaq Presario Notebook
I DON'T GET A PICTURE WHEN I HOOK UP MY LAPTOP TO MY TV MONITOR.
on your laptop keyboard, press function button & monitor button at the same time .
Oct 18, 2008 | Computers & Internet
Hook up on input 3
if your tv and laptop have a s-video connection you can get a cable and link the two up
Aug 17, 2008 | Mitsubishi WD-62725 62" Rear Projection...
KWorld PC to TV Converter
I had the same problem. It turned out the issue was that I had the VGA Y-cable connectors between the PC and the KWorld box reversed. They look like they should be interchangeable, but they are not. A closer look at the cable connectors shows that one is marked "PC", one is marked "Monitor", and the 3rd is marked "SCAN CNVTR". Once I got them plugged into the right places, I got the screen image on the TV.
Jan 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
Dell Inspiron 8000 Notebook Logo
Alun Cox
