Question about Canon PIXMA MP780 All-In-One InkJet Printer
Distinct ring feature
I already have it set to fax only but it still picks up all calls. The phone company said I need to set the fax machine to have a distinct ring
  • Thomas Lim
    Thomas Lim May 11, 2010
    You can check my premium solution answer. Ive now put in the required steps. Sorry i wasnt able to check my answer a while ago it seems I wasnt able to past the whole thing. Please give me feedback by commenting on the thread under premium in your my profile section
  • Thomas Lim
    Hold on let me double check
  • 928 Answers
I see youve seen the solution already. Glad to know it was fixed.
Posted on Aug 13, 2008
Hp fax machine does not picks up incoming fax calls automaticly
check your settings to ensure that it is set to automatically answer fax calls. Also ensure that if you have distinct ring tone service that you have that feature enable properly for the ring tone that denotes faxes.
Sep 06, 2014 | HP LaserJet Pro M127FN Laser Multifunction...
Distinct ring function for fax?
Setting The Receive Mode
  1. Press <FAX>, then press <Menu>.
  2. Press <OK>.
  3. Use [<]or [>] to select the receive mode.
  4. Press <OK>.
Aug 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Fax maching not letting Phone Calls Through
Easiest solution is to buy a fax /phone sitch from Radio Shack
Aug 17, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
HP 1040 "JUNK " FAX MACHINE
can hp 1040 fax transfer printed copies to hp pavillion note pad
eadyj1948@yahoo.com
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
