Question about iRobot Vacuums
Roomba just runs in small circles - iRobot Vacuums
I just recently had someone bring in a roomba discovery and all it would do is stay in a tight 4 tile area and go in circles. battery was fully charged and all bumpers were clear.
i took a can of air blast for cleaning computers and blasted the area on the bottom underneath the sensor and watched as several dust bunnies came flying out.gave it a few more blasts for good measure and put it back on the floor and hit power then clean buttons.
thing went in same tight circle for 2 passes then the circle got bigger for 2 more passes , blue light indicator came on and it made a straight line dash across to closed door and started following the edge and criss-crossing the room.
called the owner back in to test and it repeated the same moves when she started it and all appeared to be working normal again.
Posted on Oct 21, 2008
  • 126 Answers
SOURCE: roomba just runs in small circles
It's little brain is having a seizure. Really! It's a programming fault. If you look on the machine, usually the bottom, you'll find a 1-800 number you can call and they have a solution for it. It's fairly common for this to happen and it cannot be solved with any mechanical solution.
Posted on Jan 27, 2008
  • 61 Answers
SOURCE: roomba red 4100 cleans in small circle stops
When the status light comes on, the Roomba is going to sing "uh-oh," and then beep a number of times. Count the beeps. They're a code that tells you what's wrong with the Roomba. You can check iRobot's website for a chart of beep codes. Search "What is Roomba saying to me?" on the troubleshooting page.
Posted on May 15, 2009
emissionwiz
  • 77529 Answers
SOURCE: Roomba only circles back and forth in a very small
either the infrard sensor is defective or the steering is defective
Posted on Jun 29, 2009
  • 66 Answers
SOURCE: The Roomba goes around in circles. If it
Are you sure it is 10 beeps ?
look in your user's manual, the beeps code is there with some
suggestions how to solve it
Have fun
Avi
Posted on Apr 12, 2010
SOURCE: Roomba going in circles
Roomba going in circles. Called irobot and if reseting it (by taking out the battery, unplugging it from the charger, and holding down the power button for 30 seconds), didn't work, turn the roomba over, take a compressor and blow air into the front. Maybe a shop vac would also work. We cleaned out the whole thing while we were at it. And now it works just fine. The tech person at irobot was very helpful.
Posted on Oct 16, 2010
Goes around in a circle and won't go forward was working fine untill my husband cleaned it out with tweesers
sounds like one of the motors on the wheels stop working making it go around in circle and not forward
Feb 16, 2011 | Roomba Vacuums
Roomba starts out in a circle goes wider and wider then all at once goes in circles.
when it starts doing that hit the start button again then wait a few sec.
Jul 19, 2010 | iRobot Roomba 560 Robotic Vacuum
Mar 14, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
Roomba 560 goes in circles then stops and blinks power indicator
Actually, this is the Circle Dance Error. You can find a fix for it here or if you want more information about the Roomba Circle Dance Error.
Dec 21, 2009 | iRobot Roomba 560 Robotic Vacuum
Turns in circles, acts like it hits a virtual wall then stops
Reboot is probably not your solution. Your Roomba will react to invisible signals or 'interference' from other electrical appliances as well as the invisible wall boxes. You can clearly see how this happens when a Roomba gets near your computer or other device that is on. Also, the Roomba will go in circles when the dirt chamber is full or it thinks it's full. Try a thorough clean of all major parts including the brushes. Sometimes this activity will occur when the brushes get snarled on thread or carpet fibers.
Oct 09, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
My Roomba 560 has started to run in small steps as if it constantly meets an obstacle and turns around in a very small circle. It advances slightly, backs slightly and turns and then does this again and...
It probably does think its met an obstacle. It could be the bump sensor switch remains pressed, one of the 4 cliff sensors on the front is dirty, or one of the 3 wheel drop sensors (left right and caster) is alarmed. Clean the sensors and your problem may resolve.
Oct 04, 2009 | iRobot Roomba 560 Robotic Vacuum
Running backwards in circles.
If your Roomba's speaker isn't working, you need a new Roomba regardless. Give a call to customer support (877-855-8593) and they'll help you out.
Jun 10, 2009 | iRobot 4150 Roomba Vacuum
Roomba red 4100 cleans in small circle stops starts agains cleans small circle stops then status light comes on and clean button blinks.
Apr 06, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
Roomba 560 just goes in a small circle, will not go forward or backwards, then a red alert lights up ststing to clean it, which a throughly good cleaning has been done, gave this as a gift to someone and...
you cleaned the wrong thing there are small ir lights on the under side of the Roomba they look lke small red buttons clean the lenses with a q-tip and, alcohol. these infrared leds are the roomba's eyes you'd go in circles too if you couldn't see obstacles.
Jan 11, 2018 | iRobot Roomba 560 Robotic Vacuum
Vacuums Logo
814 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
