WJSR2070B2WW GE Washer will not spin - Washing Machines
  • 725 Answers
Does it drain.and lock the door.. if it don't drain check you drain pump if it can't drain if will not spin...
if it will not lock the door it will not spin check the door lock..
if it locks and drains it is a motor control...
hope it helps
Posted on Aug 13, 2008
Disassemble a GE washer #wjsr2070b2ww
i believe this model actually has the capability of popping the fron panel off. make sure there are no scews at floor in the front of machine if so remove... next you want to take a small screwdriver and between the top of the washer and the front panel if you look closely you will see a tab on each side about three to four inches in. stic your flat screwdriver in there in between the tab and top portion and apply forward pressure on the front panel. repeat process to opposite side and then remove..should be enough access there to examine your problem
Dec 02, 2011 | GE WBSR3140DW Top Load Washer
WJSR2070B2WW AGITATOR REMOVAL NOISY IN SPIN . AGITATOR SPINS BUT TUB DOESN'T.
got help on another site for free that told how to remove agitator which allwed me to see the metal part that connects inner drum to transmission had completely broken into two seperate parts. will replace.
anks
bobth
Dec 06, 2009 | GE Washing Machines
Will only spin when basket is empty no water or clothes GE top load wjsr2070b2ww
this one is easy,renew the motor bushes and check for any slack in the main belt that goes around the drum and motor,rgds,paul
Jul 07, 2009 | Washing Machines
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
GE WJSR2070B2WW clogged. How do I get to punp?
G0386312.jpget the front panel off. use a putty knife and wrangle it. The electric pump will be right there on the bottom right. The pump comes apart easily. Just give it a twist. A bit of water mess. Get a washtub and put the pump in it before removing the hoses. Easy fix. The hardest part is getting the dang front panel off. :D
Dec 15, 2008 | GE WBSR3140DW Top Load Washer
Ge washing machine, trying to find out if model is a heavy duty washer model #WJSR2070B2WW serial # HF193930G
My solution was, I didn't want to pay $14.99 just to find out if the machine was a heavy duty washing machine. That's why I quit.
Oct 08, 2008 | GE Washing Machines
Washing Machines Logo
322 people viewed this question
Top Washing Machines Experts
