Question about Radio Shack Accurian ADR-0106
Tens and Tens of Different DVD's used and get rejected . . . Help?
I have been trying to use DVD to record and every brand and type gets rejecyed, out of 75 in same pack I have 9 work and then after recording 2 of those stopped be read with error not able to read. I have tried Ativa, Maxell, Memorex, and Office Depot, (DVD-R, DVD+R and DVD- or + RW). I am about to buy a Panasonic or Phillips machine. Can anyone help. My email is captohmycapt @hotmail.com.
    Genius:
  • Radio Shack Master
  • 1,673 Answers
This sounds like the laser is wearing out, or there is a laser drive fault. I have seen this many times. Unless your DVD machine is a very high end model, it may not be worth servicing.
Jerry G.
Posted on Dec 04, 2008
I have a panasonic dmr-75v dvr and it won't read blank dvd's.i tried 3 different brands of dvd's with no luck of
This machine will only accept DVD-RAM & DVD-R Discs.
All other formats of Recordable DVD will be rejected for either Recording or Playback.
Please leave feedback.
Cheers
Andy
Jun 03, 2011 | Panasonic DMRES15 DVD Recorder
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
My Samsung DVD Recorder rejects my blank DVD disc after having used it 2 years without any problem. What is causing this?
Hi, I think I have the answer. Try putting in a different type of disc, start with going to a simpler format of disc-if yoou were using dvd r/w +- for example then go to plain dvd r. If you were using dvd r's-then try putting in a data disc ( cd-r ) and try recording a song. I you can record in a simpler format I'd have to say that your samsung's probably reached the end of it's life cycle and is just plain getting weak. I'm sorry I didn't have better news. You may try a " LENS CLEANING " dvd also-as there have been cases of actual dirt being a culprit. I hope this was helpful, please comment though, Thanks and good luck , Prodzilla
Apr 13, 2011 | Televison & Video
DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
Apr 15, 2010 | Roxio Easy CD & DVD Burning
Sony DVD+R AccuCORE disc recorded on HP dv4-2045dx laptop notebook will not play on Bose 321 system Get disc incompatible message What can I do?
Sometimes dvd players will have problems playing certain types of recordable discs. You might need to switch from the Sony brand and try a different one. Also there are DVD+R and DVD-R types. The Bose might have issues trying to play a "+" type disc. Also make sure that the disc is being properly "finalized" by the burning software you are using so the Bose system will recognize the disc. The burning software I use is called Nero Burning Rom and it is very easy to use. It allows you to control the burning for various applications and can help with "problem discs". If you are able to play other burnable discs in the Bose and the Sony discs are the only one giving you the problems then it is probably just that brand and you will not be able to use them with your Bose. And just a note some older DVD burners can only burn "+" type discs or "-" type discs but not both. Your computer according to the specifications from HP should not have a problem burning both types as long as the drive is the original.
Mar 07, 2010 | Bose 3 2 1 GSX System
I'm having problems formatting discs for Panasonic EZ47 DVD recorder. Keep getting "formatting unsuccessful" message.
Now here are the types of DVDs that you can record to DVD-RAM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Now the only types that you can format are DVD-RAM, DVD-RW, DVD+RW
So first make sure you are not trying to format the wrong type of DVD. If you are using the correct type then you might want to try a different brand. Sometimes certain brands of DVDs have problems with certain players. You can also try updating your player's firmware and see if that corrects the problem also.
Jan 01, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have tried to load 5 different recordable discs in my trutech dvd record and the machine rejected all of them. What brand works in this machine??? [I tried Sony regular and re-recordable, Sony, Phillips,...
See if changing recording speed would help. As far as I know the discs should work. Try the discs that you have burned before on another player just to check if there is something wrong with the player.
Oct 05, 2009 | TruTech T650-DR DVD Recorder
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Aug 22, 2009 | Samsung DVD-R155
Unable to record.
Have you initialised the disk? The manual states that for the first use a DVD-RW has to be initialised first.
Apr 08, 2008 | Toshiba D-R5 DVD Recorder
Radio Shack Accurian ADR-0106 Logo
76 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
